stevebubs
| posted on 18/1/06 at 12:43 AM |
Made the mould...
and it separated from the buck OK (WOOHOO!!!! RESULT!!!!)
However the surface has lots of minor imperfections....however, these are easily sorted by a a bit of 400g Wet & Dry followed by 1200...and a bit
of Farecla G3...
Is this the norm???
stevebubs
| posted on 18/1/06 at 12:44 AM |
Afraid I can't get any decent pictures of the imperfections - can't get the digicam to focus...sorry....
Triton
| posted on 18/1/06 at 08:30 AM |
Imperfections as in bumps or pin holes?
Bumps are easy as you can flat them off, pin holes will produce little "pips" on the part you make.
www.tritonraceseats.com
www.hairyhedgehog.com
stevebubs
| posted on 18/1/06 at 12:37 PM |
A kind of mottled uneven effect - probably caused by the PVA?
As I said - easily sorted with some wet & dry, just curious if it was the norm....
Volvorsport
| posted on 18/1/06 at 10:39 PM |
reticulation or orange peel ?
www.dbsmotorsport.co.uk
getting dirty under a bus
Triton
| posted on 18/1/06 at 10:46 PM |
If it's the PVA mate...just try hot soapy water first...you will be surprised.
stevebubs
| posted on 18/1/06 at 10:53 PM |
quote: Originally posted by Volvorsport
reticulation
Come again?
Triton
| posted on 18/1/06 at 10:54 PM |
Same here
Volvorsport
| posted on 18/1/06 at 11:00 PM |
make sure you take your hands out of ya pockets when you say it .
basically if whatever youve gelled is too waxy , it reticulates . could/can produce the effect you mention otherwise , hot soapy water to get rid of
the pva
stevebubs
| posted on 18/1/06 at 11:10 PM |
the pva
Been washed - so is not residual PVA... thought it might be the way the PVA dried, though - the PVA was dabbed on with a sponge so didn't seem
*that* smooth....mottled marks would be consistent with this....
still drawing a blank on "reticulation"....thicko terms, please?
[Edited on 18/1/06 by stevebubs]
Triton
| posted on 18/1/06 at 11:56 PM |
maybe you got it too hot then or didn't polish off the wax and it has left it's mark.
TheGecko
| posted on 18/1/06 at 11:58 PM |
quote: basically if whatever youve gelled is too waxy , it reticulates . could/can produce the effect you mention
re·tic·u·late - adj.
Resembling or forming a net or network: reticulate veins of a leaf.
I think is what my GRP teacher called 'triping' as in 'looking like tripe' in the sense here of the actual cows stomach lining
type tripe. A blotchy, reticulated, pattern.
I'm just confusing things more aren't I ?
Dominic
Triton
| posted on 19/1/06 at 12:01 AM |
yep.....
stevebubs
| posted on 19/1/06 at 12:10 AM |
blotchy would be right....
stevebubs
| posted on 19/1/06 at 12:11 AM |
If the PVA wasn't smooth, could it have caused a similar effect?
| posted on 19/1/06 at 10:02 AM |
Reticulation looks like crackle glaze if it's what I think he means.
stevebubs
| posted on 19/1/06 at 03:37 PM |
If it is the release agent then I guess the answer to this problem is presumably more elbow grease when polishing off?
chrsgrain
| posted on 19/1/06 at 05:16 PM |
reticulation usually means looking like a net curtain - at least to me !!
stevebubs
| posted on 19/1/06 at 06:23 PM |
Reticulation it is then....thankfully didn't show up on the piece of gelcoat I laid down yesterday evening and removed today...
Did end up with what looked like some pinholes. However, after rubbing down with some 400grit W&D then 1200W&D and a bit of a polish, all
looked good
[Edited on 19/1/06 by stevebubs]
