sting
posted on 26/2/03 at 12:17 PM |
Rear Bulkhead ali panel
Anyone had problems with protruding bolts on an IRS setup when fitting the rear bulkhead panel as my o/s one appears to touch the panel. I was
thinking of cutting a hole and repaneling it so that there is no interference.
Sting
Wadders
| posted on 26/2/03 at 08:28 PM |
Yup, i have cut holes in both sides of the back panel, to clear the bolt heads, this also allows for later removal of the lower wishbone bolts, i
thought about fitting rubber grommets, but can't really see the holes causing a problem.
Al
Sting
dodgyroger
| posted on 28/2/03 at 03:49 PM |
I don't have this problem or am I misunderstanding? I just uploaded a pic of my boot area to the Photo Archive and there are no protruding bolts?
Make sure you fit the bolts forward facing so that the Nut can be removed and the bolt withdrawn rearwards without touching the rear bulkhead panel
Roger
http://www.dodgyroger.com/locost
sting
| posted on 28/2/03 at 05:55 PM |
Hi Roger
Mines a little different to yours and if i mounted the bolts as you said i would end up with it up my ar$e when sitting it in the drivers seat. so i
think i`ll have to cut a hole and hope for the best.
I must get round to doing some photos
Pic`s look good-coming on nicely.
Cheers Sting
Wadders
| posted on 28/2/03 at 06:40 PM |
Yeah, photo looks good mate
but i don't reckon that cardboard floor will be much good when it rains.
Wadders   i]
Roger [/quote
dodgyroger
| posted on 4/3/03 at 03:09 PM |
Cardboard floor - just trying to keep the weight down
