ecosse
| posted on 20/1/06 at 12:41 PM |
Aluminium sheet grade
I have been offered 1.5mm ally sheet at 39.50+vat which is 1050 H14 grade (huh?)
Can anyone tell me if this is the right stuff for forming my panels (Bonnet, sides, tunnel, etc?)
I found references in other posts to look for and ask for "half hard" but my supplier did not know what I meant and quoted me the above
grade number as what they could supply, saying anything else would have be specially ordered.
Alex
iank
| posted on 20/1/06 at 12:54 PM |
Yes, it's half hard
This site tells you more than you ever need to know
http://www.azom.com/details.asp?ArticleID=2798
So it would seem to be good stuff
"Aluminium alloy 1050 is a popular grade of aluminium for general sheet metal work where moderate strength is required.
Alloy 1050 is known for its excellent corrosion resistance, high ductility and highly reflective finish."
Bluemoon
| posted on 20/1/06 at 12:57 PM |
The H14 is the hardness, I think this is the same as halfhard?
Liam
| posted on 20/1/06 at 02:39 PM |
Don't you want 1.2mm ideally (i.e. 18 guage)? 1.5mm can be pretty hard to bend over a long distance.
Liam
Bluemoon
| posted on 20/1/06 at 03:16 PM |
I'm useing 1.6mm Half hard, and it's been find so far (90 degree bend about 1m long over soft wood with rubber hammer)...
Dan
Liam
| posted on 20/1/06 at 03:42 PM |
OK then, must have been a different grade i had major trouble with in 16 guage on my mate's car a while back...
NS Dev
| posted on 20/1/06 at 03:44 PM |
Alex
what size sheet is that? Sounds like a pretty good price if it's for an 8' x 4' sheet!!
Where's that from?
Bluemoon
| posted on 20/1/06 at 04:21 PM |
I payed somthing like £139 inc VAT and delivery to my door for 4 off 8x4 foot, plastic coated on both sides to stop scratches, can check details and
supplier tonight if you want..
James
| posted on 20/1/06 at 04:53 PM |
Hard to remember now but I *think* Ned and I paid about £25 per 8'x4' sheet from Parkers Steel.
That's 1.2mm thick, half hard stuff.
James
- Muhammad Ali
ecosse
| posted on 20/1/06 at 06:29 PM |
The quote came from here and was for 2m x 1.25 sheets, and they apparently come with a plastic
protective film on.
As they seem to be the right thing I am off tomorrow morning to collect, I was reckoning on 3 sheets to everything (sides, tunnel, scuttle, bonnet,
back end) is that about right?
Alex
PS
Going for a steel floor.
dnmalc
| posted on 20/1/06 at 11:22 PM |
Have approached my local sheet metal working firm and for him to do a special order for 1.2mm Al sheets 2.5m x 1.5m halsf hard and finished with
plastic to protect the surface he is quoting me £32 each
