Author: Subject: 600 grit ok for key?
emsfactory
posted on 22/1/06 at 01:19 PM Reply With Quote
Just a quicky. I'm preping the other halfs car for a respray. Is 600 grit wet'n'dry paper low enough to get a good key?
omega 24 v6
posted on 22/1/06 at 01:32 PM Reply With Quote
Might be ok for a key but I think you'll be able to see the marks in the final coat. I'd be tempted to go for 800 my self and a coat of fastbuild primer on top of that flatted down before the top coat. I ai'nt no body builder mind and some one will be along to shoot me down soon
stevec
posted on 22/1/06 at 01:39 PM Reply With Quote
I agree 800 or even 1200 for last rub down.
emsfactory
posted on 22/1/06 at 02:08 PM Reply With Quote
1200 not a bit high. Have used that before and the primer cracked.
posted on 22/1/06 at 04:28 PM Reply With Quote
Very depends what is going on top --
Tip -- Before keying give the panel a good T cut to take any wax off
posted on 22/1/06 at 07:55 PM Reply With Quote
T Cut has wax in it Rub it down with warm water and washing up liquid whatever grade you decide to use, then rinse it off.
Mark Allanson
posted on 22/1/06 at 08:23 PM Reply With Quote
Everyone is saying what grit to use without knowing what paint is being used.
2K paint, use 400 for solid colour or 600 for a clear over base (metallic or non metallic)
Cellulose is 400 for either
Synthetic use 800 for both.
Primer, 180 will do, proper highbuild, you can go from 80 upwards
Dont use T Cut, it has wax in it AND amonia (breaks down paint!).
Don't use washing up liquid, it contains salt.
Don't use water on primer, the primer is designed to absorb the first liquid it comes into contact with, this is ideally the next coat of paint!!
emsfactory
posted on 22/1/06 at 08:44 PM Reply With Quote
Its metallic. Is it ok to degrease with white spirit then tack cloth then paint? Thats what i have done. Some small parts look as though it has reacted. Could this be white spirit not evaporated? Some areas went on nicely.
Mark Allanson
posted on 22/1/06 at 09:14 PM Reply With Quote
White spirit should't cause too many problems if it is fully removed before painting, proper spirit wipe is made for the job, about £12 a 5 litre, wipe it on with one cloth and remove with another
Triton
posted on 23/1/06 at 10:42 PM Reply With Quote
Weird stuff paint!!!! sticks when you splash it on something and when you want it to look good and stay there....it flakes off
www.tritonraceseats.com
www.hairyhedgehog.com
