Author: Subject: Matt finish cellulose - do I need lacquer?
Avoneer
posted on 4/2/06 at 05:52 PM Reply With Quote
Does "matt" finish cellulose need lacquer on it to protect it, or is the lacquer just to make it shiny and the paint will do fine on its own???
Pat...
ecosse
posted on 4/2/06 at 06:53 PM Reply With Quote
If you laquer a "matt" finish, you will turn it into a gloss finish (don't ask how I know this)
Alex
Avoneer
posted on 4/2/06 at 09:18 PM Reply With Quote
So is matt tough enough on it's own to withstand chips etc ???
I can see how the laquer would make it shiny, but won't it still look matt through the shiny laquer ???
Pat...
ecosse
posted on 4/2/06 at 09:28 PM Reply With Quote
I had the same problem on a bike I painted, I needed a Matt section for the belly pan, but wanted to protect it from stone chips so tried the lacquer route, and ended up with full on gloss finish
It might be possible to mist the lacquer coat on and achieve a matt type finish (??), might be worth a try (can of matt spray paint and a can of spray lacquer and see what happens)
Alex
Mark Allanson
posted on 5/2/06 at 12:52 AM Reply With Quote
Just buy 10ml of matting agent
NS Dev
posted on 6/2/06 at 01:28 PM Reply With Quote
.......................or get me to paint it on a bad day and I can make most gloss a matt finish anyway!!
