Author: Subject: Yet another fibreglass question
RazMan
posted on 10/3/06 at 11:38 PM Reply With Quote
I have now got my door skins for my middy - inner and outer. When they are bonded together they will make a very rigid (but light) gull wing door. The question is, what should I use to bond the two together?
PU Adhesive or resin? The PU might give a slightly flexible bond which is less prone to cracks (they will inevitably get slammed occasionally) but the resin option might be stronger.
Waddya think?
Raz
owelly
posted on 10/3/06 at 11:58 PM Reply With Quote
I would tend to think that a bit of flex would help! The resin is brittle so a bit of Sikoflex type stuff would be best.
http://www.ppcmag.co.uk
Triton
posted on 11/3/06 at 12:25 AM Reply With Quote
Bonding paste
www.tritonraceseats.com
www.hairyhedgehog.com
scotty g
posted on 11/3/06 at 07:38 AM Reply With Quote
Agree with Triton, bonding paste, available from from any GRP supplier is the best thing. Its like a thick grey resin, you mix in the catalyst the same as resin and dollop it on with an old butter knife (thats what i use anyway), then clamp the two parts together. Curing time depends on how much catalyst you use just like the resin. Cheers.
RazMan
posted on 11/3/06 at 10:10 AM Reply With Quote
Aha - I haven't come across this paste before. It sounds like it is designed for the job.
I will toddle off to my supplier next week and see what he's got.
Raz
Raz
emsfactory
posted on 11/3/06 at 10:59 AM Reply With Quote
Yep. Agree with them above.
RazMan
posted on 13/3/06 at 05:23 PM Reply With Quote
I went to my usual supplier for resin & paints (well mainly paints) and when I asked for bonding paste I just got a blank look!
Has anyone got a link or a trade name I can look for?
Raz
Hugh Paterson
posted on 14/3/06 at 07:52 AM Reply With Quote
Bonding paste is resin thickend to a "peanut butter consistancy" by the addition of a glue powder, in other words ya can make it yerself! the alternative is to give CFS a bell. A search on yahoo or google will find their contact details they do mail order.
Shug.
RazMan
posted on 14/3/06 at 08:46 AM Reply With Quote
Thanks for the info - I found CFS here but they dont list bonding paste or glue powder I'll give them a ring later and see what they recommend.
So is the bonding paste just a resin / filler mix? If so can I just thin some P40 down with resin and then add my normal catalyst?
*edit* I phoned them and they do a product called Gravacol which is not on their website. It is a two pack bonding paste which cures to a slightly flexible finish - sounds ideal
[Edited on 14-3-06 by RazMan]
Raz
Triton
posted on 14/3/06 at 10:04 AM Reply With Quote
Raz,
Ring CFS and ask for Alex....good bloke who knows his stuff.
Mark
RazMan
posted on 14/3/06 at 10:51 AM Reply With Quote
Thanks Mark, I found a stockist quite near to me in Canvey Island (30 mins away) As the postage charge for this type of stuff is exhorbitant I will nip down there and get it.
Raz
Dutchman
posted on 14/3/06 at 11:06 AM Reply With Quote
i would do it with epoxy glue strong stuf I glued my fiberglas evo 6 scoop on my bonnet still is on the hood
Tarzan English with foreign accent!
RazMan
posted on 14/3/06 at 11:03 PM Reply With Quote
Got some bonding paste now - £15 for a 2.5Kg tin including catalyst ..... bargain!
Raz
Triton
posted on 14/3/06 at 11:07 PM Reply With Quote
Have fun with it....can be very messy unless it's just the way I use it....
RazMan
posted on 14/3/06 at 11:13 PM Reply With Quote
I was thinking about nicking the wife's cake piping bag and putting a bead 10mm thick around the areas to be bonded, clamping them up with Cleco pins and letting the whole lot go off overnight.
Raz
