Poll: Aerodynamics of wet weather gear? (poll) [View Results]
Without full wet weather gear (roof, sides)
Just a tonneu
side screens
nothing
wind blocker
Author: Subject: Aerodynamics of wet weather gear? (poll)
Lawnmower
posted on 18/4/06 at 08:25 PM Reply With Quote
What goes quicker?
a car with full side screens roof,wind blocker etc?
or nothing?
or somehere in between?
remember more kit = more weight....
more kit = more drag?
tom_loughlin
posted on 18/4/06 at 08:36 PM Reply With Quote
aaarrrggghhh my dissertation coming back to haunt me.....
Tom
k33ts
posted on 18/4/06 at 09:09 PM Reply With Quote
itll be more aerodynamic if you took the spare wheel off the bonnet
tukcustoms.com
Krismc
posted on 18/4/06 at 09:13 PM Reply With Quote
i agree and mybees Remove the front and back window too!
Lawnmower
posted on 18/4/06 at 09:20 PM Reply With Quote
might be a bit nippy, us landy drivers need to keep as much heat as possible, think i get more heat through the transmission tunnel than the heater!
omega0684
posted on 19/4/06 at 01:34 AM Reply With Quote
you would definately get a better 0-60, if you cleaned all that crap of the landy too
Guinness
posted on 19/4/06 at 06:47 AM Reply With Quote
"Aerodynamics are for people who can't build engines". -- Enzo Ferrari
I wouldn't worry about weather gear, or lack of it, it's the nut behind the wheel that controls the speed
Mike
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
Building: a pile of bits that will someday be a fisher fury
posted on 19/4/06 at 05:16 PM Reply With Quote
side screens hood etc might actually improve the aerodynamics of a screened car because it prevents the turbulence behind the screen from getting as large. most convertables work this way with the roof up.
Krismc
posted on 19/4/06 at 07:47 PM Reply With Quote
Screen, he he if only one was available
posted on 19/4/06 at 08:09 PM Reply With Quote
Screen? Who has a screen?
Rob Palin
posted on 20/4/06 at 07:54 AM Reply With Quote
For a standard 7 the difference between roof up & side windows and a fully open set-up is 16%. Assuming everything else being equal and gear ratios optimised etc etc, that should be worth about 8% on top speed. Worth doing then.
Interesting that Ferrari now put huge emphasis on aerodynamics, both for road and race cars. I guess the Old Man would be spinning in his grave, though perhaps not as rapidly as if he'd sorted his aero out...
ned
posted on 20/4/06 at 08:14 AM Reply With Quote
I can't believe the results of this poll it just shatters my logic completely!
having a screen and weather gear is of course going to add to air resistance etc and doing without them is going to make the car have a lower frontal area to push through the air. The next point in my mind is drag.
Those who have selected the 'nothing' option obviously haven't thought about this. full doors are obviously no good (or can't be fitted) without a screen but half doors and/or a tonneau cover across the passenger seat are going to smooth the airflow over the cabin and severely reduce the turbulence and hence the drag coefficients for the car.
I don't mean to sound arrogant but to me it seems like such a no brainer.
dons tin hat and ducks for cover (quack)
ps i recall someone posted a model of a 7 with air flows over the car, possibly a uni dissertation or something- who was that?
[Edited on 20/4/06 by ned]
beware, I've got yellow skin
Rob Palin
posted on 20/4/06 at 08:59 AM Reply With Quote
Ned's right. Switching from a full screen to an aeroscreen will reduce the drag force acting on the car.
However, it doesn't actually change the drag coefficient very much. The CD is a 'shape factor' and takes several things into account, including the frontal area. With the full screen the actual drag force acting on the car goes up but then so does the frontal area and, in this case, by almost the perfect amount to leave the drag coefficient the same, at around 0.61.
Fundamentally the 7 is just the wrong shape; the widest/tallest part of the car is right at the back. Anyone seen many aerofoils or teardrops shaped that way? Nuh-huh.
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
posted on 20/4/06 at 10:23 AM Reply With Quote
my point was if youve got a screen then the roof etc will probably reduce drag over no roof but with a screen. no screen is obviouly better for 2 reasons 1 less frontal area and 2 lower Cd due to the very unaerodynamic flat screen.
Cd or drag coefficient does not change with frontal area (thats the whole point of it) the idea is that a scale model that is geometrically the same but a different size will have the same Cd but a different frontal area, this is why Cd is usefull for model testing in wind tunnels.
a screened 7 has a Cd of about 0.65 which is about 2x that of a normal car an un screened one is just over 0.61 iirc. something like a fury/phoenix etc will have a Cd of about 0.3 with a screen and about 0.26-0.27 with out (less difference as the screen is curved) but they have a very similar frontal area to a 7 so have massively less drag, hence a phoenix gaining 10-15mph more speed at the end of a long straight over an indentically chassis striker.
Rob Palin
posted on 20/4/06 at 11:09 AM Reply With Quote
I think the CD of the Fury/Pheonix is closer to 0.4 at best, and certainly nowhere near 0.26 in any configuration.
Only the Audi A2 and Toyota Prius dip below 0.27 and the best open-top car currently in production is the Merc SL which has a CD of 0.33 hood down.
To get below 0.3 you need to do a lot of work on planform shape and detail optimisation around the wheels & underfloor. It would have to be a very special car to drop below 0.3 without a full cockpit cover of some sort.
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
posted on 20/4/06 at 05:42 PM Reply With Quote
the fury/phoenix has a far more rounded front end with a much lower bonnet profile, a flat floor with no mechanical parts hanging down, comparatively small front grill, and no shut lines.
0.4 is more than an old beetle or equivalent to an average suv/pick up. a tonneaued fury with the lemans bonnet and a smallish roll bar will be well under 0.3
something like this but with a tonnaeu
Rob Palin
posted on 20/4/06 at 08:49 PM Reply With Quote
Well, the front side corners are rounded but there's an extremely short overhang and they leave the front wheels very exposed - terribel for both drag and lift.
The centre section of the bonnet has way too smalla radius for the flow to stay attached around it and so you'll get separation right at the leading edge.
The cooling air has nowhere else to exit other than the underfloor or front wheelarches. If it is allowed out the underside then it will render an otherwise flat floor redundant. If it exits through the front wheelarches then there would need to be a sizable radius on the back edge of the wheelarch, blended into the side otherwise you will get an enlarged front wheel wake increasing the effective frontal area very significantly.
Shut lines make next to no difference to the drag of a vehicle unless they are in an area on the edge of separation already or if there is substantial aspiration through the gap (like around a poorly-sealed bonnet).
Having an open cockpit with short rear body will mean that the flow cannot reattach before reaching the back of the car, making the effective base area much bigger than the actual car geometry. This will be exaggerated by the flared rear wheelarches and the lack of useful boat-tailing at the rear of the body.
Tonneau covers don't always make a fat lot of difference, especially if used in conjunction with a windscreen or air deflector of sorts. On my Locost the cover made a difference of 0.008 to my CD of 0.61...
The CD of an old Beetle is actually comfortably in excess of 0.5. That sort of figure may still be reasonable for a poor pick-up truck but most SUVs are now down between 0.38 and 0.45.
I don't mean to sound disrespectful but there is no chance in the world that the Pheonix has a CD less than 0.3. As part of my job i maintain a database of the aerodynamic characteristics of (almost) every major production car which extends back to 1961. During that time no manufacturer has made an open-top sports car with a CD below 0.3. 0.33 is the best i can find. Bearing in mind that some of those cars will have spent around 1000 hours in the wind tunnel during their development, i think it's quite unlikely that Sylva managed it with zero hours and despite having some clear flaws in the design as mentioned above.
It is still a very pretty car, and a damn sight more slippery than a 7 but there is a fair bit of room for improvement.
tom_loughlin
posted on 28/4/06 at 10:23 PM Reply With Quote
Just re-read this thread, and some of the numbers quoted for the Cd of this type of car are well off. Cd is a relationship between the forces experienced on a body and the size of the frontal area - thats how the scaling factor comes into play.
i can say 100% that no se7en has been anywhere near Cd 0.5.
I could show pictures, but im starting to bore even myself now....
cossey
Contributor
Posts 430
Registered 5/12/05
Location Kent
Member Is Offline
Photo Archive Go!
posted on 29/4/06 at 07:03 AM Reply With Quote
caterham teted on of their 7s in a wind tunnel the result was 0.62 from memory. (it was definantly over 0.6)
drag coefficient is the ratio of the drag force to the dynamic pressure x area so it is a measure of how slippery a shape is which a screened 7 (ie what was tested) definantly isnt.
