Author: Subject: Cracked RS2000 Alloy Sump.
The Baron
posted on 19/4/06 at 05:38 PM Reply With Quote
I’ve got a crack in my RS2000 alloy sump (bummer!!!!)
Has any one tried to weld aluminium using aluminium wire in their MIG welder?
Or has any one tried the Lumiweld Kit from Frost Restorers equipment?
Cheers in advance,
The Baron.
Surrey Dave
posted on 19/4/06 at 05:52 PM Reply With Quote
There was a lot of good comments about 'Alutight' at Detling show,low melting point aluminium welding with a blow lamp, kind of super soldering I guess , similar to 'Lumiweld' it was £25 a metre .
daytonadean
posted on 19/4/06 at 06:33 PM Reply With Quote
you can ali weld with a mig using pure argon. some migs weld better than others though ??
dean
PaulBuz
posted on 19/4/06 at 07:09 PM Reply With Quote
I have welded my ali sump with my mig welder.
Secret is cleanliness & a very high wire feed rate in comparison to welding steel.
With a bit of practice fairly good results can be achieved
Paul
paulbeyer
posted on 19/4/06 at 08:28 PM Reply With Quote
Where abouts in South Glos are you Baron? I live in Thornbury but more to the point so does my Dad. He's a TIG welder and might be able to take your sump to work and sort it out for you.
Send me a U2U and see if we can arrange something. (No promises until I speak to my Dad though).
7 out of 10 people suffer with hemorrhoids. Does that mean the other 3 enjoy them?
paulbeyer
posted on 24/4/06 at 09:25 PM Reply With Quote
Problem sorted?
