zzr1100rick
| posted on 26/4/06 at 06:18 PM |
body work dimensions
Hi ive got a luego with a zetec fitted and when measureing the height of the engine from the chassis rails i make it 10 inches at the front and 11
inches at the rear
My question is which bonnet scuttle and nose cone will fit ?
as lugeo body work may take some time to appear cheers Rick
MikeR
| posted on 26/4/06 at 06:25 PM |
are you sure about those numbers? That seems incredibly high!
the standard caterham nose is around 17cm from the chassis rail to the top. Most noses are an inch or two higher so that makes 8 or 9 inches high at
the front of the GRP nose.
pathfinder
| posted on 26/4/06 at 06:33 PM |
I recon mk is probably the best bet! I’m in the same boat so shall be at stonleigh with my tape measure trying to work out what scuttle will fit my
velocity bonnet!!!
