Author: Subject: rear arches
dilley
posted on 2/5/06 at 03:56 PM Reply With Quote
rear arches
Ive fitted a set of 17's to my indy there the correct offset but seem to be rubbing even when cambered in, I quite like the dax ones, does anyone know if they fit?? also dax say they are 15" wide, seems a bit much to me or are they wider at the top only and taper in???
posted on 2/5/06 at 04:06 PM Reply With Quote
You might think about modifying the ones you have if they only catch occasionally, get the grinder round the inside lip and cut some off, especially when you see Dax prices.
Wadders
posted on 2/5/06 at 05:47 PM Reply With Quote
Hi Dilley
out of curiosity, how wide are standard MK rear arches measured across the top ?
Ta
Al.
dilley
posted on 2/5/06 at 08:26 PM Reply With Quote
they measure 290mm external and about 280/285mm internal.
