James
posted on 11/4/03 at 03:14 PM |
Ali panels- to brush or not to brush
Just at the stage of thinking about the ali sheet I'll need for sides/rear. I'm not quite sure what to ask for when ordering though.
I'm after the sort of 'brushed' effect as opposed that with a mirror like surface.
Is one a 'standard' type and the other something unusual in which case which way round. Also, is it just called 'brushed' or
is there a proper name for it?
Dumb question I know- nothing unusual there then!
James
Jasper
| posted on 11/4/03 at 03:27 PM |
Can't answer that one, but do get it with the plastic coating on both sides, bit of protection from scratches, and you can draw on it with a
marker pen! Mine is just regular shiny stuff.
I got a company in Kent to deliver, I think it was about £100 for 3 sheets. Let me know if you need their number and I'll try and find the
receipt.
flyingkiwi
| posted on 11/4/03 at 04:39 PM |
Don't know if ali comes in a brushed effect, but I know how to make it.
Scotchbright
Good stuff. If you can get hold of the round discs that you stick on the end of a drill all the better as it saves a lot of elbow grease. but a couple
of minutes wizzing about the panel will dull the surface a little and produce a nice brush effect.
The only downer would be the reduction in the ali's natural coating to protect itself agains corrosion, as by brushing it you tend to rub it
off.
If you can't get hold of some give me a shout and I'll grab a couple for you from work!
Chris
It Runs!!!!! Bring on the SVA!
Stu16v
| posted on 11/4/03 at 04:40 PM |
James, the trouble is with 'brushed' is that you may end up buying more than you would actually need to panel the car, due to the fact
that even though you have enough ali to panel section 'x', the grain of the brush effect will be in the wrong direction, if you get my
drift.
Cheers, Stu.
James
| posted on 11/4/03 at 06:56 PM |
Chris, thank you for the offer- most kind of you. I think I've seen it for sale around here but will contact you if not!
Good point about the corrosion- presumably one could apply some sort of spray on laquer or something...?
Stu, the cost of style over function- when will I learn!
Cheers Jasper, will bear it in mind if college don't want to be helpful!
James
paulf
| posted on 11/4/03 at 08:46 PM |
You can also use green scouring pads of the type that i think women use for washing dishes, not really found that a good use but they are good for
polishing alloy.
Paul.
Scotchbright
off.
Chris
stephen_gusterson
| posted on 11/4/03 at 10:47 PM |
wow
sexism.
they work for guys as well!
but not me, I have a dish washer.
atb
Rorty
| posted on 12/4/03 at 01:44 AM |
If you use the fine grade of 3M/Scotchbrite disc with a backing pad in a drill, the brushed effect will be random, therefore, it won't matter
about having to orientate the sheets as you would with proprietry uni-directional pre-brushed sheets.
Plain or polished AL sheet will show up every little scratch and blemish, whereas the brushed finish won't to the same degree.
The surface will self-harden in a short period of time too, though an application of laquer or wax will help to protect it.
Cheers, Rorty.
| posted on 13/4/03 at 08:22 AM |
Cutting compound.
The kind you use on cellulose paint before you T cut and wax. It's a bit like valve grinding paste and is applied in straight lines unlike the T
cut which goes in small circles. You would avoid the problem of lines in different directions if you treat the panels after the car is built and you
have the option of changing your mind.
yours, Pete.
