indykid
| posted on 15/5/06 at 12:33 AM |
cutting carbon
i've bought a carbon aeroscreen off ebay, but it's untrimmed.
i'm just wondering if anyone has any experience of using dremel type brown grit cutting wheels to cut wet lay carbon. i've used them for
GF, but not CF. i found a thread that recommends carbide grit edged saw blades, but with the convex shape, i think a jigsaw would probably end up
scratching something.
i dont want to bugger it up and have to buy another though, so would prefer actual experience rather than the usual myth and conjecture do it right
or do it twice!
cheers in advance
tom
Tangerine Scream
| posted on 15/5/06 at 06:15 AM |
I just used the bigger black GRP cut off discs in a dremel cutting 3mm thick (ish) wet lay CF
Went through it as easy as GRP.
Took my time though, as I do get carried away with the dremel
HTH
RazMan
| posted on 15/5/06 at 07:02 AM |
The carbide jigsaw blades work fine - just cover everything in masking tape to prevent scratching.
Raz
smart51
| posted on 15/5/06 at 07:15 AM |
CF is easy to cut - much easier than GRP. It sands really easily too. A saw or a serated kitchen knife or anything will cut it but a fine toothed
blade will give a nicer cut than a coarse one.
Phil.J
| posted on 15/5/06 at 09:24 AM |
Cutting CF
Cutting carbon composites is straight- forward enough with a disc or fine toothed sawblade, and the edges with sand easilt to a good finish.
The complecation is when they are reinforced with kevlar as this is tough and tends to give a fuzzy edge.
As with all composites, do wear a mask when cutting as the particles are really fine and can go deep into the lungs.
greggors84
| posted on 15/5/06 at 10:44 AM |
Where did you get it from tom? Was it a supplier, or just someone who had one?
Chris
The Magnificent 7!
jono_misfit
| posted on 15/5/06 at 12:05 PM |
Its a good idea to cover up when cutting carbon, and as said above wear a mask.
If you use a dremel etc. with a thin cutting disc the dust given off is very fine. Dont know about everyone else but it gives me a rash where i come
in contact with it. Its also a bit itchy but not as bad as glass.
Usually when i cut it, i put a stip of masking tape down on the front / finish side, mark a line with a pen and cut using a small air grinder with a
thin cutting disc. Work slowly and you get a really good and straight finish.
Works well, but very dusty hence the above.
indykid
| posted on 16/5/06 at 09:11 PM |
it's from 2.0xevauxpower on ebay. it's the one that's been linked to on here quite often. looks like it'll fit an indy well
after a bit of fettling. he's not got any for sale atm, but has had a couple up of late.
hth
tom
oh, thanks for all the tips people! think i'll try the dremel cutting wheels. bit more control than most things.
[Edited on 16/5/06 by indykid]
