Author: Subject: ali pannel round front wishbones
johnemms
posted on 2/6/06 at 12:56 PM Reply With Quote
As it says in the title - do i do a book job and cut all the holes in the ali side panel ?
Or .. is it lazy but ok to stop at the first of the wishbone brackets and put a folded edge there leaving a nice engine breather hole ??
cheers guys
jon
flak monkey
posted on 2/6/06 at 12:59 PM Reply With Quote
Personal preference is to panel it in. But some of the kit companies actually finish the panel short of the nose anyway.
Its up to you!
Sera
http://www.motosera.com
posted on 2/6/06 at 01:25 PM Reply With Quote
Finish at the fu tube and save some pain and time.
mark chandler
posted on 2/6/06 at 01:32 PM Reply With Quote
I found this to be the hardest most frustrating thing to do to date !
Take off the bones, get a big piece of card and cut holes in it, tape the holes up and move them around etc until you have the result you want (do not forget that the lower edge of the chassis is not the same as the lower edge of the panel, imagine a vertical line directly from the top rail down as your reference), only then think about cutting the ali.
IMHO leaving it open looks horrible !
Even after spending a day at this I'm still going to have to chop some stainless up to make some neat surrounds for the holes.
Look at Foozie's photo's for inspiration.
Regards Mark
posted on 2/6/06 at 01:40 PM Reply With Quote
I did the same as Mark - got some decent card from an art shop, glued enough sheets together to cover the area, then taped it to the chassis with the corect bend and shape. Made some rough holes where I thought I needed them, then fitted the wishbones and steering rack and checked for fit. I fixed anything that needed fixing by gluing more card where necessary and trimming it.
Once I was happy with it I took the card pattern and marked its shape onto the ali sheet.
SeaBass
posted on 2/6/06 at 03:23 PM Reply With Quote
Much the same here... we used lining paper to make up the template...
Then transferred onto ali...
Looks far better than open...
kaizokuace
posted on 2/6/06 at 05:29 PM Reply With Quote
maybe if you really didnt want to do the ali panel holes and still wanted it to look decent maybe i dunno i just thought of it but cant a leather cover be fashioned around there? similar to the shifter. plus dirt protection! I dont know if this would actually look fugly. but if someone does it and it looks cool then i might try it haha!
TangoMan
posted on 3/6/06 at 09:04 AM Reply With Quote
jon
This is how my Formula27 is done. I am planning to make a plate to fill the hole as I think it lets the car down.
