nitram38
| posted on 18/6/06 at 11:43 AM |
M6 gutter bolts and sva
I have used these on my wheel arches instead of bolts as they are dome heads, but they have washers underneath that extend a few millimeters outside
the head. The washers are flat against the arches.
My first question is whether these will pass sva and second, are there any caps I could fit over them?
I have seen small bolts that have a flat plastic washer with cap attached that snaps over the head.
Are these made in a size big enough to fit over a M6 gutter bolt?
I have the usual sva M6 black dome caps and I could change the gutter bolts to hex type, but the high domes of the caps would look a bit ugly.
Deckman001
| posted on 18/6/06 at 12:17 PM |
They would only look ugly to and from Red house Road though wouldn't they
Jason
nitram38
| posted on 18/6/06 at 12:29 PM |
Probably!!!!!!!!!
Seriously though, I would like to leave them as just dome head bolts and not have to change them.
The stupid thing is, has anyone looked at the ariel atom?
Link
The bolts are cap heads and are exposed on their suspension, no edging on wheel arches and coilovers have no protection.
How do they get away with it?
Maybe they 'lost' the bolt caps after ESVA?
Deckman001
| posted on 18/6/06 at 12:38 PM |
I've used M5 cap heads on my front mud guards and might still need some silicone to fill the hex bolt area try the same with M6 they
aren't That much bigger are they ??
re the Atom, if you were selling a design like that , would you leave all the sva rubber bits on it for promo shots ??
Jason
RazMan
| posted on 18/6/06 at 12:39 PM |
Why not use the mushroom heads which are usually stainless and look pretty good - I've used them whenever I could find an excuse
Raz
nitram38
| posted on 18/6/06 at 02:24 PM |
Any chance of a picture of 'mushroom heads'?
RazMan
| posted on 18/6/06 at 02:55 PM |
Actually they are button heads
inky
Raz
nitram38
| posted on 18/6/06 at 05:09 PM |
Cheers for the link. I will be off to my local supplier in the morning.
russbost
| posted on 18/6/06 at 06:41 PM |
Think you'll find if you check the SVA manual (Yawn, Yawn) that if it protrudes less than either 3 or 4mm (can't remember which ottomh)
then it doesn't count as regards the radii checks?
nitram38
| posted on 18/6/06 at 07:07 PM |
Russ, they will look better than the gutter bolts anyway.
