johnemms
| posted on 22/6/06 at 11:01 AM |
Headlight Mounting Ideas
Hi all..
Trying to work out best way to mount headlights....
1. make a bracket that uses the bolt at the top of the shocker.
2. make an 'A' shape bracket that uses the bolts on the top suspension arm.
3. weld a bar to the side of the chassis and panel round it.
4. Bolt a bar to the top rail of chassis and cut out 'U' shape in nosecone.
I like the idea of ajusting the headlights up n down in case i change the lights later on.... any comments ? pitfalls etc?
cheers ........
scoop
| posted on 22/6/06 at 11:20 AM |
Im having the same problem of deciding what to do with my lights at the moment but i hadnt considered the up and down movement of them. In that
respect the A frame has got to be the way to go. It takes the caterfield idea that little bit further doesnt it?
Steve.
graememk
| posted on 22/6/06 at 12:00 PM |
i have spare mk light bar in chrome £10 + pnp bolts on top of the car through the nose cone fiberglass
dr-fastlane
| posted on 22/6/06 at 03:35 PM |
I would say weld a bar to the top rail of chassis and cut out 'U' shape in nosecone.
Look in my picture archive there must be a picture where you can see how I did it. If not, I will make one for you
Greets Roy.
I have not failed once. I have successfully found ways that will not work!
https://www.motor-forum.nl/threads/hardtail-dragstyle-project.343482/
Bob C
| posted on 22/6/06 at 04:39 PM |
I made a bracket that uses the top wishbone bolt and the top shock bolt. The advantage being that I used the headlight bracket to solve the SVA radius
problems on these parts... dunno if it will cut the mustard yet though...
I'll post a foto if you want
Bob
johnemms
| posted on 22/6/06 at 04:55 PM |
ahhhh wishbone and shock bolt i'll have a look at that.......
cheers
