Author: Subject: Wider rear wings
scoop
posted on 29/6/06 at 04:29 PM Reply With Quote
Wider rear wings
Anyone know where i could get some wider rear wings?
I have two sets of GTS wide ones already but even at 11" they wont go over my 17" wheels. I figured it will be cheaper to change the wings than buy a new set of wheels.
James
posted on 29/6/06 at 04:58 PM Reply With Quote
I'm not sure how good they look but have you seen the way Robin Hood do it on their car?
Only the outer couple of inches is GRP, the main 'flat' area of the wing is ali sheet presumably, therefore, you can adjust the width.
Could you modify yours by inserting an ali section in the middle maybe?
Hope that helps,
James
EDIT:
Just remembered DAX! Their wings are huge (or atleast appear to be! )
[Edited on 29/6/06 by James]
chrsgrain
posted on 29/6/06 at 05:19 PM Reply With Quote
Yep - they're huge!
scoop
posted on 29/6/06 at 06:32 PM Reply With Quote
Didnt want all that hassle
My mate has got a Robin Hood but its only running on 15's. Ill ask him to measure up for me.
scoop
posted on 29/6/06 at 09:05 PM Reply With Quote
There was a guy on ebay selling ones 13" wide but cant find him now.
Anyone?
russbost
posted on 29/6/06 at 10:23 PM Reply With Quote
The Mirach uses big arches, they are what i've used on my Furore. Front tyres ae 245x50x18 rears are 285x45x18 (on mine that is - the Mirach uses !7's). I can search Robs number out if you want it?
scoop
posted on 30/6/06 at 07:54 AM Reply With Quote
I'll not turn anything down.
Thanks,
