R1 STRIKER
| posted on 11/7/06 at 02:12 PM |
prep before laquer
After a small incident on a roundabout in tin top (not my fault!) I have
had to do a repair to wing. Just want to know what's the best way to prep the new paint before aplying lthe laquer? (fine wet and dry or cutting
compound etc).
Ben.
| posted on 11/7/06 at 02:20 PM |
I used 100 wet'n'dry on a key scratch done to the door of my volvo
I use a thin piece of wood, ~ 2mm wide to sand down just the raised paint; then sprayed on the laquer with air brush (it was narrow scrape).
I thnk I finished it off with t-cut.
PaulBuz
| posted on 11/7/06 at 03:38 PM |
100 sounds a little course.
I'd use 400-600 wet
Paul
thunderace
| posted on 11/7/06 at 05:34 PM |
what paint is it metallic two pack. 1K ACRYLIC ,Cellulose ,
Mark Allanson
| posted on 11/7/06 at 08:32 PM |
Get grey automotive scotchbrite from a bodyshop supplier - designed for the job
R1 STRIKER
| posted on 11/7/06 at 09:35 PM |
Thanks for the advice guys.
It's metalic silver aerosol. Am on second attempt. Audi suplied paint was miles off. Amazingly, halfords tin is a good match. Never going to be
perfect with out getting a pro to do it but looking pretty good so far. Quite pleased!
Ben.
| posted on 12/7/06 at 10:48 AM |
quote: Originally posted by PaulBuz
100 sounds a little coarse.
I'd use 400-600 wet
oop!! missed out a 0; should be 1000 but you really knew that
