PaulBuz
| posted on 14/7/06 at 04:40 PM |
Nosecone grill
Do I really need one?
I neveer seen one yet that I like the look of, but I really do like the way the Rush does it..open with just a bar.
The problem is I don't want anyone to think I'm making a Rush copy.
Do I NEED to fit anything for SVA?
Paul
scotty g
| posted on 14/7/06 at 04:55 PM |
I believe you need to have something there for SVA, give it some thought and get creative mate.
BKLoco has done a tidy job on his one
Confused but excited.
| posted on 14/7/06 at 07:48 PM |
I bought a chrome plated trivet from Woolworths, for the princely sum of £4.
It is 500mmm x 240mm and is made of 7mm dia round bar. I think it will look the dogs b@ll@cks when it's cut down to suit.
Michael
| posted on 14/7/06 at 07:57 PM |
I have a Fire Guard, which was found in a neighbours skip. Still in flat pack stage in storage, looks good, and may get to use the main frame of it,
then the grill in the middle.
John Bonnett
| posted on 14/7/06 at 08:28 PM |
I made my grille using 1/8" stainless steel wire. I made a jig so that the shape was right. I bent the wire for the outer frame and welded in
the horizontals and verticals. It was easy to make and inexpensive and best of all, it looked good.
John
PaulBuz
| posted on 15/7/06 at 12:27 PM |
Cheers for the ideas, although I'd still rather leave it open if thy will let me
Paul
John Bonnett
| posted on 15/7/06 at 04:47 PM |
Just remember how vulnerable you radiator is without a grille.
John
| posted on 17/7/06 at 02:09 PM |
tesco shopping trolley, as found in a canal near you.
caber
| posted on 17/7/06 at 03:13 PM |
Get something, spray matt black and mount as deep as you can inside the nosecone then you won't see it. You will need to trim nose opening
carefully.
Caber
