se7ensport
| posted on 14/7/06 at 07:05 PM |
Fixing grill and side vent- how???
Got a bit of a problem, can't work out how to fix my grill to the inside of my body work and the same goes for the side vent.
issue 1
I've bought the stainless mesh that is woven together and so it moves a bit like an extending garden fence (XXXX style).
issue 2
I initially thought about using some fibreglass bridgeing compound, but as I've already painted the body the reaction is likely to cause
distaution to the outer surface.
issue 3
The side vent is next to exhaust down pipe so what ever I use will need to be able to withstand a fair degree of heat.
The only thing I can come up with is to use some very small dome top bolts through the body work, but I'm not a fan of this option, any other
suggestions greatly received...
thanks
Alex
| posted on 14/7/06 at 07:12 PM |
We used PU adhesive to bond grill mesh to back of GRP. Works fine and should stand up to heat pretty well.
Phil
kev R1
| posted on 14/7/06 at 07:16 PM |
bend it back around the mouth of the grill and use some sikaflex!
se7ensport
where can I pick some PU up from, b&q?
whats the consistance like i.e. silicon sealant or wood glue (is it likely to run!)?
Alex
tegwin
| posted on 14/7/06 at 07:24 PM |
For example:
The grille on the lower part of the front splitter on the Morgan Aero8 is held in place by what are basically threared studs glued to the GRP
moulding...the mesh is then pushed over the stud and a nut is put on....
Problem we had was that the studs sometimes come loose when overtightened
esn163
| posted on 14/7/06 at 08:39 PM |
Alex
Our local B&Qs didn't sell it but we found machine mart does at about £6. Its just a bit thicker consistency that ordinary silicone
HTH
Ed
Edit found a link but sure somewhere else must be cheaper since our local diy shop is
only £4
[Edited on 14/7/06 by esn163]
Indy Build Photos
** Build pages **
Photo Bucket Pics
Simon
| posted on 14/7/06 at 09:01 PM |
Cable ties.
I used body filler on mine.
Simon
