Author: Subject: Gelcoat with Wax = Flowcoat = Shiny or not?
stevebubs
posted on 27/7/06 at 09:19 PM Reply With Quote
If I add the 5% wax to my gelcoat to make topcoat, will it still buff up as nicely as the gelcoat?
[Edited on 28/7/06 by stevebubs]
Volvorsport
posted on 27/7/06 at 09:55 PM Reply With Quote
wax stops it going sticky if your using it on a roof etc , ie not in a mold
www.dbsmotorsport.co.uk
getting dirty under a bus
RazMan
posted on 27/7/06 at 10:11 PM Reply With Quote
Isn't gel with added wax called flow coat?
Raz
Chippy
posted on 27/7/06 at 10:53 PM Reply With Quote
Razman, sure is called Flow coat, and as stated is used to produce a Gel coat finish without a mould, usualy in places like the bilges of boats, to make them easier to keep clean. As far as using it to get a good finish on a rough outside moulding, well you can, but what a bloody job, best to use body filler, and spray the thing. Regards Ray
stevebubs
posted on 27/7/06 at 11:00 PM Reply With Quote
yes - flowcoat.
so flowcoat can be sanded and polished to a similar finish to gel?
Chippy
posted on 27/7/06 at 11:39 PM Reply With Quote
Problem with sanding Flow coat, or any gel coat, is that the heat generated melts it and clogs the abrasive, and as said in my previous post it's a bitch to get nice and flat. Personaly wouldn't bother, just a good body filler, sand it down and spray it. Will take less time and save you from a whole lot of grief. IMHO. Regards Ray
stevebubs
posted on 27/7/06 at 11:58 PM Reply With Quote
Except I'd have to spray the whole Fury.....not cheap...but I do have loads of gelcoat and sandpaper. So long as I can get a reasonable finish for now then I'll be happy and will go for the perfect job when I can afford it...
[Edited on 27/7/06 by stevebubs]
RazMan
posted on 28/7/06 at 07:52 AM Reply With Quote
If you are forced to stick with what you've got, you might be able to achieve a better finish by hand and doing it wet - should help with clogging.
Raz
Dave J
posted on 28/7/06 at 10:01 AM Reply With Quote
As Raz said, I would definately rub it down wet using ever finer wet and dry paper. I did this to great effect to remove orange peel effect on my gelcoat, finishing off with very fine acrylic polish. lovely job.
Dave
stevebubs
posted on 28/7/06 at 03:02 PM Reply With Quote
So - to summarise from the original question...
I should be able to get as good a finish with flowcoat as with gelcoat...
RazMan
posted on 28/7/06 at 03:32 PM Reply With Quote
IMO the wax might prevent getting a 'full on' shine but you should be able to get a reasonable finish.
Raz
Triton
posted on 30/7/06 at 09:11 PM Reply With Quote
Use tissue as last layer then flowcoat it
stevebubs
posted on 30/7/06 at 11:32 PM Reply With Quote
Hmm...got a bit further in now...and loads of sanding to do.
Have dremelled out the join and filled with gelcoat, and put a load of tape on to allow it to air dry.
In some places on the join, the gelcoat is likely to be 8-10mm thick...is this going to give me problems later?
posted on 30/7/06 at 11:40 PM Reply With Quote
If the join was not reinforced with tissue on the front side then it stands a good chance of cracking IME...
