Author: Subject: sticky back plastic body work???
nib1980
posted on 28/7/06 at 09:17 AM Reply With Quote
Morning all,
Now I've had an idea, and want to run it past you.
As I'm tight, and not good at painting, I was wondering about covering the ali panel of my car with sticky back plastic to give them some colour. I Know the risk of bubbles etc, but has this ever been done and what were to results?
Many thanks on your opinions
splitrivet
posted on 28/7/06 at 09:28 AM Reply With Quote
Why bother just polish her up.
Bob
joneh
I would use a colour fast vinyl as plastic will fade quick.
HTH.
posted on 28/7/06 at 09:37 AM Reply With Quote
interesting idea but my gut feeling is it will cost more than paint.
to get a good finish spraying needs a biut of practise but people have achieve acceptable results (on land rovers) using a fine foam roller (for radiators).
you would need to use etch primer for best results.
if your sitcky placcy works out cheaper give it a go - there an many buses & cars covers with this stuff for advertising; not sure how durable it would be and it if falls off, then you can always paint it.
nib1980
posted on 28/7/06 at 09:42 AM Reply With Quote
Hi all,
I've found a company that supplies exterior colour fast plastic (sticky), durable for a minimum of 7 years, @ £18 a roll, so I'm very tempted to try it, unless you know some where to get cheap etch primer and paints from? (please)
Tangerine Scream
posted on 28/7/06 at 09:49 AM Reply With Quote
Something like this?
linky
ISTR it's all done with the same stuff they use to stick decals on yachts
RazMan
posted on 28/7/06 at 10:13 AM Reply With Quote
In the trade it is called a 'wrap' and uses a 10 year plastic film. To get a good, bubble free finish takes a lot of practice but is possible, although some compound curves will be a challenge to say the least.
If plain coloured panels are required then paint 'em.
Raz
bernie955
posted on 28/7/06 at 01:53 PM Reply With Quote
They do it on taxis all the time. Can't see a problem.
Maradona
posted on 28/7/06 at 02:28 PM Reply With Quote
Here in Argentina is a new fashion, put to new expensive cars these sticky vinyl plastic material, here I see most and most Audis, Mercedes, BMW with these material in black opaque, loks really nice.
chhers
Maradona
RazMan
posted on 28/7/06 at 03:29 PM Reply With Quote
They do indeed - and it's never a problem until you have a try yourself
Raz
froggy
posted on 28/7/06 at 05:11 PM Reply With Quote
it certainly works but i wouldnt like to have a go myself, there is a sign place opposite my garage and they do vans with fully covered sides ie;sky vans and its one of those jobs that need many hands
