Author: Subject: hair line cracks
rjs
posted on 10/8/06 at 10:10 PM Reply With Quote
hair line cracks
wants the best thing to do with hair line cracking in grp on the front wings ?
apart from buy new ones .
thanks
RazMan
posted on 10/8/06 at 10:39 PM Reply With Quote
Grind the cracks down through the gel coat to the matting - you want to achieve a 'V' shape. Then fill them with a good quality body filler and finally prime & paint.
[Edited on 10-8-06 by RazMan]
Raz
locostv8
posted on 10/8/06 at 11:34 PM Reply With Quote
Stop drill either end or it will most likely continue after the repair.
http://wrangler.rutgers.edu/gallery2/v/7slotgrille/hssss/
posted on 11/8/06 at 06:40 AM Reply With Quote
full thickness cracks or normal gel goat staring ?
If latter just grind out and repair/reinforce with woven mat and surface tissue.
Full thickness cracks have to have holes drilled at the end as crack arrestors, the ground down and woven mat aplied to both sides.
mackei23b
posted on 11/8/06 at 07:20 AM Reply With Quote
Agree with previous comments, when painting you may want to use an isolator to stop the paint mapping round the filled area.
rjs
posted on 11/8/06 at 10:20 AM Reply With Quote
thanks all for that . that was a big help .
