Author: Subject: papier-mach front wings....
posted on 4/10/06 at 03:59 PM Reply With Quote
don't laugh, but serioulsy, any one considereed making front wings from papier-mache?
(obviously varnish/paint them so they don't go soggy in the rain)
Sacal
posted on 4/10/06 at 04:19 PM Reply With Quote
You sure your brain hasnt gone soggy already?
John Bonnett
posted on 4/10/06 at 04:20 PM Reply With Quote
Trabant made most of their bodies with the stuff!
RazMan
posted on 4/10/06 at 04:24 PM Reply With Quote
Have you been sniffing the brake fluid again?
Raz
iank
posted on 4/10/06 at 04:33 PM Reply With Quote
Unless you're planning on a primary school finish GRP would be a similar effort (if a tad more expensive).
posted on 4/10/06 at 08:25 PM Reply With Quote
Paper Mache cycle wings? Should go nicely with a chassis made from cheese straws
Seriously if money is a concern see if you can snag a pair of "seconds" from one of the manufacturers. They almost always have the odd panel with flaws in it. You might not get a pair with matching colour, but a bit of filler and a respray and jobs jobbed.
Otherwise you could maybe buy a pair of trailer mudguards. Most of them are made from three straight lines rather than a curve so they look pretty awfull, but they are cheap as chips and you should be able to pass SVA with them.
caber
posted on 4/10/06 at 09:18 PM Reply With Quote
Fine until it rains
Caber
joneh
posted on 4/10/06 at 09:35 PM Reply With Quote
Isn't paper mache quite stiff? It won't give when knocked like glass fibre and probably crack if you even lean on it.
RazMan
posted on 4/10/06 at 10:38 PM Reply With Quote
.. but at least you will have something to read while working on the car
Raz
posted on 4/10/06 at 11:39 PM Reply With Quote
They were Duraplast, fibreglass type resin with wood pulp which could be pressed into shape so it was easy for moulding panels. It did swell in damp conditions though.
StevieB
posted on 5/10/06 at 07:39 AM Reply With Quote
Now there's an idea for an interesting car bodywork - made using newspapars as the top layer when laying up the GRP.
I'd have it, anyway!
Marcus
posted on 5/10/06 at 08:02 AM Reply With Quote
Hmm, got me thinking now
Crossword and a couple of sudokus for the traffic jams!
Marcus
Because kits are for girls!!
posted on 5/10/06 at 08:26 AM Reply With Quote
it was just a thought.
WWI planes were made from wood, cloth and wire and Mr Morgan made his chassis from Ash. And as was pointed out, the (in)famous Trabant.
The waterproofness is the drawback with this idea .
I am thinking of making up some wings (unless I get some of ebay at a ridiculously low price).
What are the properties for wings - i.e. how stiff/heavy should they be? The ones I have are Caterhams with home made square steel supports and I think the wings can be made much lighter.
So thinking of making a buck from mine - cover with cling film then use papier mache to make the former with wood supports (don't want to risk splashing resin over my wings).
Then it is a matter of how many layers of mat? To reduce weight without loss of strength I am thinking of making a matrix from paper tubes then covered by mat and maybe incorporate the stays into the wing.
James
posted on 5/10/06 at 10:14 AM Reply With Quote
Making it ultralite would mean no more snapped wing stays!
Good on you for thinking outside the box!
James
posted on 5/10/06 at 10:47 AM Reply With Quote
Good on you for thinking outside the cornflakes box!
thats the idea but they need to be strong enough to withstand being pelted by gravel.
chriscook
posted on 5/10/06 at 05:25 PM Reply With Quote
don't forget the amount of lift that the cycle wings generate
t.j.
posted on 5/10/06 at 06:45 PM Reply With Quote
ultralite and lift = flying a locost
[Edited on 5/10/06 by t.j.]
Schrodinger
posted on 5/10/06 at 07:58 PM Reply With Quote
I don't think cling film will protect the GRP surface but brown parcel tape and/or acetate sheet (as used in overhead projectors)will give you a good protection and reasonable release.
[Edited on 5/10/06 by Schrodinger]
Grintch
posted on 6/10/06 at 09:09 PM Reply With Quote
Actually, just a month ago I was reading about a homebuilt sports racer from the 60's that used paper mache bodywork. Car looked good, surprisingly, and was compained over a couple of years. His next homebuilt car used fiberglass if that says anything.
Martin Chassis
Also known as the PMY and the Paper Mache' Special
H Modified
http://sports.racer.net/index1.html
(look under Chassis - P - Paper mache)
MikeRJ - I really like the rollcage on the car in your avitar. Is that your car? Can I get some more pictures? I checked your Photo archive but didn't anything but some early stage frame pics.
[Edited on 6/10/06 by Grintch]
posted on 7/10/06 at 10:46 PM Reply With Quote
That's because it's a different car! I was itching to get something to drive this summer so cheated and bought a registered but engineless, ex-track Striker. The locost poject still awaits...
A few more pics at http://www.mikerj.clara.net/striker/
The rear section is the standard Striker roll bar, the rest was fabricated by the previous owner. What is nice is that the windscreen and wet weather gear still fit ok.
If you want some specific detail drop me a U2U and I'll take a pic for you.
[Edited on 7/10/06 by MikeRJ]
Grintch
posted on 11/10/06 at 02:43 PM Reply With Quote
Thanks. Looks nice, I normally don't like the high front cages, but this one is different.
Ahh, U2U. We use a different term here in the States. I was trying to figure out how to send you a private message, but U2U didn't register.
G
