Author: Subject: edging trim
dilley
posted on 7/10/06 at 10:18 PM Reply With Quote
edging trim
I have cut a new hole for my exhaust in my side panel, if I leave an inch gap all round the single exhaust pipe can I use rubber edgeing trim on the edge or will it melt??
what is a safe(ish) distance for this trim in relation to the exhaust as I have other areas Id like to use it.
Thanks Andrew.
posted on 8/10/06 at 08:05 AM Reply With Quote
I put rubber trim around the front and rear edges of my lolocost silencer , silencer is knackered but the trim is still ok .Would have thought that using it to trim around the side panel would be OK .
posted on 9/10/06 at 10:31 AM Reply With Quote
I did that too, trim survived but SVA man failed it as not durable enough, go figure.
scutter
posted on 9/10/06 at 11:45 AM Reply With Quote
I didn't use trim there, just cut the hole close enough to the pipes and then the SVA man can't contact the edges with his sphere.
ATB Dan.
[img][/img]
NS Dev
posted on 10/10/06 at 09:11 AM Reply With Quote
was that still ok for the " sheet metal edges must be turned back by 180 degrees" bit in the manual???
Be nice if it was, cos I have the same problem around my exhaust and filter in the bonnet.
scutter
posted on 10/10/06 at 09:36 AM Reply With Quote
Yes it passed all sections, return edges and the sphere test, I think the bonnet edges may be looked at closer as some idiot may stick there finger in a bonnet surface.
ATB Dan.
NS Dev
posted on 10/10/06 at 06:44 PM Reply With Quote
oh ok, jolly good!
I have no folded returns on the bonnet either, but I can whack edge trim round that for SVA
cheers
Nat
