Author: Subject: Adding Header Tank on Hayabusa
adriane
posted on 26/11/06 at 11:35 PM Reply With Quote
I am currently plumbing the Hayabusa engine in my MK Indy and need help with regard to fitting the header tank which I got from MK Engineering. Does anyone know where the 2 outlet pipes (one top and one bottom) on the header tank have to go. I am using a VW polo radiator by the way which does have a small pipe outlet at the top of one of the side chambers.
RazMan
posted on 27/11/06 at 12:11 AM Reply With Quote
Usually you would fit the lower outlet to the water pump feed hose. This ensures that the pump always has a good head of water. The upper connection can be blanked off in some cases or alternatively connected to a high point in the system (your rad top connection perhaps?) to act as an automatic bleed.
[Edited on 27-11-06 by RazMan]
Raz
