Author: Subject: Fibreglass bodywork painting, anything special?
the_fbi
posted on 26/12/06 at 09:27 PM Reply With Quote
My aeroscreen currently doesn't match any of the colours on my car, so I'm looking to spray it.
Anything special required when it comes to prepping/spraying fibreglass?
Just scotchbrite pad, primer, 800 w&d, primer, 800 w&d, colour?
Any advice appreciated.
ta
Chris
[Edited on 26/12/06 by the_fbi]
Chippy
posted on 26/12/06 at 11:05 PM Reply With Quote
One of the most important things is to make sure that all the release agent has been removed. I am no painter, but have always relied on a mechanical bond, rather than self etch primer, by giving the item a good rub down initialy with 240 ish grade w & d, then primer surfacer, and rub down with 1200 grade prior to top coating, and finaly laquering. HTH Ray.
RazMan
posted on 26/12/06 at 11:43 PM Reply With Quote
A good quality etch primer is as essential as a good keyed surface imo. Otherwise just treat it like normal bodywork with base coat & laquer.
Raz
the_fbi
posted on 27/12/06 at 12:13 AM Reply With Quote
Another concern I have is that it has to be flexed to put it on the scuttle, so I may just prep it now then spray it when its in place.
Only problem is that means I can't spray it in a warm environment.
worX
posted on 27/12/06 at 11:55 AM Reply With Quote
Flex
Just fit it within a day or so of painting and even if it does flex it won't matter as the layers OR depth of paint won't have dried fully and therefore won't crease or crack etc.
should be fine...
HTH
Steve.
Syd Bridge
posted on 27/12/06 at 12:44 PM Reply With Quote
Ok, so every man's an expert and got his own way of doing things......
So,....forget all the etch primers on grp.Waste of time, money and effort. Clean off with 'body wipe', thinner, or similar. Wipe on wet in one direction, then wipe off with a clean cloth each time. When it makes a noise like 'chalk scratching a blackboard' when you drag your finger across it, it's clean.
Sand with 240-400 Frekut paper. Then a coat of two pack epoxy primer.
After the two pack epoxy, you can use any top coat you want.
At least that's how I've done it for at least 30 years, and most of the marine industry has for as long as I remember. The best two pack epoxy primer comes from Awlgrip. Also used on most yank aircraft. But only comes in US gallons.
Syd.
