auzziejim
| posted on 20/1/07 at 02:57 PM |
exhaust cut out
so...how did you do yours?
having just bought an MK exhaust manifold and bolted it up i now need to cut the bonnet for clearance but really dont wanna ahem bugger it up
so whats the easiest way of doing this and getting it right?
cheers
james
phoenix70
| posted on 20/1/07 at 03:23 PM |
I don't think there is any easy way to do it, just take your time , measure twice and alway cut less than you need, you can't put it back
but you can cut more.
I did mine piece by piece until I was happy with the fit.
Danozeman
| posted on 20/1/07 at 04:28 PM |
I masked mine up with masking tape, measured up the positioning of the exhaust. Marked up the bonnet so the cut out was slightly smaller than i
needed cut that out, then cut it bit by bit till i was right. I cut it using my black and decker wizard and cutting disc.
Take your time and wear a mask...
Dan
907
| posted on 20/1/07 at 04:36 PM |
It's the old Corn Flake box trick.
Clamp it to the chassis rail and hack away.
When your happy with the shape of the hole, use it as a template to mark the bonnet.
p.s. must be Kellogg's. You don't want any of that locost muck.
Paul G
meany
| posted on 20/1/07 at 05:54 PM |
as 907 says.
i do it to make holes in the RC planes.
1. fit your exhaust without the bonnet.
2. use a card template, clamped/taped to the chassis side.
3. cut the hole in the card board allowing a little clearance.
4. slit the card to allow removal of the exhaust.
5. remove exhaust
6. fit bonnet
7. use the cardboard as a template to mark the bonnet.
8. cut with confidence.
9. replace bonnet and check against your template.
note: the card is never removed from the chassis at all, not untill you are completey happy.
meany
| posted on 20/1/07 at 06:28 PM |
would like to add that this is how i intend to do mine...eventually..lol.
it aint rocket science.
907
| posted on 20/1/07 at 07:23 PM |
Yeah, but have you seen the size of the exhausts on them rockets ?
bob
| posted on 20/1/07 at 08:22 PM |
Yup card template or you could have my old pinto bonnet, bit to far away though
