Author: Subject: Fuel filler hose
myeates
posted on 25/1/07 at 02:59 PM Reply With Quote
Fuel filler hose
hi guys anyone know where i can get some fuel filler hose from but needs to be a 90º bend one end 50mm(2inch) and the other about 45mm. any ideas appreciated
regards
mark
wilkingj
posted on 25/1/07 at 03:05 PM Reply With Quote
Its Flexflyte tubing. Expensive, but you can do that in one bit of it.
Very bendy 2" pipe from Europaspares
Best Regards
Geoff
http://www.v8viento.co.uk
posted on 25/1/07 at 06:49 PM Reply With Quote
Don't use a 90 degree bend, put the filler on the top deck . Putting filler on the rear panel makes it a right pain to fill the tank . Next car will have filler inside the rear deck.
myeates
posted on 25/1/07 at 07:10 PM Reply With Quote
thanks will have a look i may not have room for it on the back rear panel anyway so was thinking about putting on top but will still need a tube with the reducer may take a trip to scrapyard first then buy somthing
RazMan
posted on 25/1/07 at 10:34 PM Reply With Quote
Europa do some 90 degree bends. The pukka stuff is not cheap though.
Raz
Jon Ison
posted on 25/1/07 at 11:02 PM Reply With Quote
agree, also means if your unlucky enough too be rear ended the filler pipe don't get ripped off leaving a gaping hole into your fuel tank
