Author: Subject: Anybody know where i can rent one from?
novacaine
posted on 9/2/07 at 04:02 PM Reply With Quote
i guess this is the right place to put this question,
anybody know where a mate of mine can rent a spraybooth for a car for a weekend whilst he paints his car?
distance doesnt matter too much
Matt
PeterW
posted on 9/2/07 at 04:37 PM Reply With Quote
Why....???
Line a garage with DPC plastic sheet... That assumes you have the gun, compressor etc tho...
Pete
novacaine
posted on 9/2/07 at 04:44 PM Reply With Quote
just because you can get a better quality finish from a spraybooth with the fancy extraction etci assume but i dont realy know much about this kind of thing,
what quality of finish do you get from garage-based spraying?
Matt
And you run and you run to catch up with the sun but its sinking, Racing around to come up behind you again, the sun is the same in a relative way but your older, shorter of breath and one day closer to death
PeterW
posted on 9/2/07 at 05:11 PM Reply With Quote
Matt
Depends what you are spraying. I've sprayed cellulose in a single garage and got a very good finish. Its all about preparation, and taking your time. Dust is not as big an issue as some people would have you believe !
Also, if you don't have a very good compressor and gn, buy a HVLP unit as they are so much easier to use.
Peter
novacaine
posted on 9/2/07 at 05:25 PM Reply With Quote
thanks for the tip, i'll be sure to pass it on,
