The Doc
| posted on 25/2/07 at 06:10 PM |
Primers
Anyone tried using aluminium self etching primer on GRP? Just that I have some Hammerite stuff that's water based.
| posted on 25/2/07 at 10:47 PM |
GRP doesn't need etching, flat it down and use normal primer.
| posted on 25/2/07 at 11:08 PM |
The only reason to acid etch GRP is if you really want to F up your lungs LOL
Otherwise just sand and spray!!!
Only problem would be if you use epoxy 2 pack on polyester GRP- the old polyester / epoxy bonding thang being a problem.... But then your lungs
won't be a problem cos you'll be using the full breathing gear!!!
Polyester / epoxy works but not particularly well without a sealant in between.... Though I'm sure people still don't bother!!!
The Doc
| posted on 27/2/07 at 07:15 AM |
I find roll ups best for that
