mad dad
| posted on 25/2/07 at 06:36 PM |
Rear arch beading
Can someone tell whats the best to use, where can i get some and the silly question.....how do you fix it! Cheers???
dilley
| posted on 25/2/07 at 06:42 PM |
do you mean the rubber strip between the arch and the body?
mad dad
| posted on 25/2/07 at 06:44 PM |
Hi dilley, yep thats the one...
Humbug
| posted on 25/2/07 at 06:45 PM |
It's often called tadpole beading (because if the cross section). You can get it from places like Woolies
http://www.woolies-trim.co.uk/c-322-extrusion.aspx
To fix it you bolt through it i.e.: bolt-washer-wing-beading-bodywork-washer-nut
dilley
| posted on 25/2/07 at 06:47 PM |
Ive got loads of it I think....... You know where I am
mad dad
| posted on 25/2/07 at 06:59 PM |
does this mean the arch has to be off to fit it??? cheers dilley will pop in and see you sometime
mad dad
| posted on 25/2/07 at 07:01 PM |
cheers humbug having read yours again yes the arch is off the car..........been a long day......................
Chippy
| posted on 25/2/07 at 11:44 PM |
Hi, you don't have to take the arches of, just loosen all the bolts and then just slot the piping where it needs to go round them. Once you have
tightened the bolts back up it won't come out, its how I fixed mine, not moved yet. HTH Ray
