matt page
| posted on 25/3/07 at 08:23 PM |
Front mudguards - alternative mounting??
hi, i took my locost out for its first road test today and noticed that the front mudguards are wobbling about alot. The mountings are as standard
using dimensions from the book... is there an alternative way of fastening them on?
Matt
omega0684
| posted on 25/3/07 at 09:14 PM |
got any pictures of the mountings? have you tried using any adhesive like wurth for example.
Humbug
| posted on 25/3/07 at 09:31 PM |
Are the wings wobbling away from the mounts, or are the mounts themselves wobbling?
I used to have what I think are fairly standard mounts (triangular plate + tubes with flat bar welded on) on Cortina uprights and like many people I
suffered first from wobbling, then with breaks. After several attempts to beef them up I ended up making new ones from much thicker bar (no tubes) and
used the triangular mounting plates to align them. No problems now.
matt page
| posted on 25/3/07 at 09:39 PM |
Its the whole mount that is wobbling, they are made to book dimesions and bolted on to sierra hubs. I think i will beef them up as you suggested.
Thanks alot
Matt
Humbug
| posted on 26/3/07 at 06:55 AM |
Here's my post on the new mounts I made. I used 1/8" x 1/4" (c 29mm x 6mm) bright steel bar... so far, so good.
http://www.locostbuilders.co.uk/viewthread.php?tid=55793
matt page
| posted on 26/3/07 at 03:40 PM |
thanks humbug, il give it a go. anything will be better than what i have got now. its so frustrating watching them wobble when on the road
Matt
Jon Ison
| posted on 26/3/07 at 04:03 PM |
The problem went away fro me when I did this.......
The two arms are joined together by a bit of flat bar with a hole big enough for the top ball joint too pass through......
