myeates
| posted on 14/4/07 at 08:27 PM |
Rear light mounting
hi guys just bought the lights pictured with the spacers but from the back of the lights to the plug with wires is still 70mm, i think these are going
to stick too far in the wheel arch is there any way i can extend these out 30mm or so more without buying the expensive mounting boxes that are £50 a
pair any ideas
stevec
| posted on 14/4/07 at 08:31 PM |
I have the same and its close.
I think you can get right angled bulbholders for them from SVC,
Steve.
UncleFista
| posted on 14/4/07 at 08:44 PM |
pair any ideas
If you have narrow arches, the mounting boxes may not fit, they didn't on ours
Tony Bond / UncleFista
myeates
| posted on 14/4/07 at 08:54 PM |
no problem on width of arches as we had to make them wider to fit think there in the region of 25cm wide. had a look on S-V-C and they sell the
reverse and fog with the right angle holders but would appear not to have them on there own
steve did you put the right angle holders on yours
[Edited on 14/4/07 by myeates]
stevec
| posted on 14/4/07 at 09:03 PM |
I just got away with it, There is about 15mm clearance, But all our cars are different.
You may have go with the pods.
Steve.
myeates
| posted on 14/4/07 at 09:07 PM |
will have a proper look in morning with new eyes might be able to modify rear arches a bit to blend it all in a bit better than getting pods should of
thought about the size before
stevec
| posted on 14/4/07 at 09:22 PM |
It was more luck than judgement for me.
Deep little mothers eh?
Steve.
rayward
| posted on 14/4/07 at 09:26 PM |
got the same ones on my indy,
Image deleted by owner
they do fit, but its close.
Ray
RichardK
| posted on 14/4/07 at 09:27 PM |
I was looking at the very same ones, can you do me a favour and post the diamentions on them please.
Don't suppose they can be packed out with something like a coffee jar lid or something?
Rich
Gallery updated 11/01/2011
stevec
| posted on 14/4/07 at 09:45 PM |
The lamps are 95mm diameter and the bases are 100mm diameter.
That the only dimension i can remember without a visit to the garage.
Steve.
myeates
| posted on 16/4/07 at 04:02 PM |
think i may be able to just get away with it. after a careful look.
do the lights have to be mounted vertical i know the fog does for sva but what about other lights ?
darrens
| posted on 16/4/07 at 05:52 PM |
I bought these and found that the indicator ones (mounted to the outer edge) would scuff the tyre on full suspension drop. So I swapped the two
indicator ones for the right angled versions.
do a search on http://www.europaspares.com for LX101
same as others but with a right angled connector
[Edited on 16/4/07 by darrens]
