Author: Subject: Broken my Aeroscreen - Advice please
whitestu
posted on 28/4/07 at 07:08 PM Reply With Quote
I got my new screen from Mac 1 yesterday and tried to fit it today.
After a bit of sanding to make the profile fit, I marked the holes, rested it on my bench and stared to drill it.
On the second hole it went snap and split int
o two pieces.
Do you think I've been too rough with it - I didn't try to drill it particularly slowley as I thought it would be quite strong. It was a warm day today so it shoudn't have been brittle.
Could it have had a flaw that caused the crack, or have I just been a bit of a numpty?
It was only £30 so not the end of the world.
I haven't called Mac 1 yet, but will on Monday to see what they think.
Stu
jos
posted on 28/4/07 at 07:27 PM Reply With Quote
how close to the edge was the hole you were drilling?
whitestu
posted on 28/4/07 at 07:56 PM Reply With Quote
1cm from the bottom, and at least 5cm from the side.
stu
mangogrooveworkshop
posted on 28/4/07 at 09:16 PM Reply With Quote
Drill bit was too sharp.......it is the case when drilling polyc that a sharp drill is the wrong tool.
you use a dull bit and it doesnt try to screw its self into the plastic.
Mark Allanson
posted on 28/4/07 at 09:21 PM Reply With Quote
What sort of drill were you using, a standard 60° HSS generates too much torque on lexan (quite a high friction material). I think a wood drill or a spot drill (same principle) would do a better job as it cuts the outer circumference of the hole before removing the waste material
whitestu
posted on 29/4/07 at 07:15 AM Reply With Quote
It was a normal HSS metal bit.
I'll try a wood one next time.
Stu
jimgiblett
posted on 29/4/07 at 09:04 AM Reply With Quote
Doesnt sound like it was polycarb. In which case not a good idea for a screen.
- Jim
worX
posted on 29/4/07 at 10:14 AM Reply With Quote
Give MAC1 a call (as you probably are) they are top blokes and am sure will help out as much they can!
Steve.
