andrew-theasby
| posted on 28/4/07 at 07:09 PM |
side pael idea
Hi, anybody seen/got a picture of a car with side panels like this one i made up? Are there any problems with this (supposed to b like 3 big luvres)?
I know in theory it will lose a bit of torsional stiffness but that shouldnt make a massive differece would it? I intend to make the middle panel
removeable but well held on if you know what i mean. ps, hope you dont mind if this is your car
andrew-theasby
| posted on 28/4/07 at 07:10 PM |
forgot the picture
arrybradbury
| posted on 28/4/07 at 07:57 PM |
SVA sharp edges?
blakep82
| posted on 28/4/07 at 08:36 PM |
torsional striffnes shouldn't be an issue, as i'm sure that panel does not bear any weight (i'm not building a seven) but, as said
above, do it after SVA
________________________
Pdlewis
| posted on 28/4/07 at 08:48 PM |
my car has one on each side. massivly reduced the under hood temp. If you see my avatar or look in my archive you can see the front has black
pannels the overlap the stainless by arround 3 inch and are off the stainless by arround 1 to 1.5 inch
bimbleuk
| posted on 29/4/07 at 07:29 AM |
Even just one will make a difference and even more so if you panel the underside as well.
andrew-theasby
| posted on 30/4/07 at 07:57 PM |
Yes i appreciate the sharp edge issue thanks, but id just have to cover it with edging strip for the test. Nobody got any pictures of more than one
vent?
[Edited on 30/4/07 by andrew-theasby]
iank
| posted on 30/4/07 at 10:20 PM |
louvres and grills used for engine cooling just have to be blunted IIRC. That said you never know what an inspector is going to decide
Anonymous
