locoboy
| posted on 29/4/07 at 06:11 PM |
painting MDF
I have a small bit of MDF on my dash that i need to paint black.
Is there a special paint i need to use or will any old paint adhere?
I would prefer to aerosol paint it but brush would be ok if i had to.
I dont just want to slap it on and see if its ok, because it took me ages to make the bit and i dont want to F**k it up!
Locoboy
designer
| posted on 29/4/07 at 06:14 PM |
Emulsion paint is usually use on MDF
SeaBass
| posted on 29/4/07 at 06:20 PM |
Best to use something like a PVA water mix 50/50 to seal the MDF first. Then flat it back and use whatever paint you like... If you don't then
paint will soak into the material and look crap.
joneh
| posted on 29/4/07 at 06:21 PM |
As above, or use an MDF primer. About 5-10 quid from B&Q. It'll stain easy if you don't prime it.
Dale
| posted on 29/4/07 at 06:22 PM |
Melemain (spelling) kitchen paint.
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
locoboy
| posted on 29/4/07 at 06:34 PM |
PVA mix it is then.
You cant see much of it as its behind my clocks but i still want it to look neat.
Locoboy
balidey
| posted on 29/4/07 at 06:35 PM |
Dale
Yep, another vote for Melamine (?) paint from me, no priming needed, and if i remember, pretty cheap too.
The Baron
| posted on 29/4/07 at 06:41 PM |
I made my dash from 19mm MDF, put the radii on it (19mm on bottom edge, 9mm every where else) then sealed it with PVA before painting the back with
hammerinte (rough but effective) and covering the front with vinyl.
smart51
| posted on 29/4/07 at 08:02 PM |
Carefull painting MDF. If any part of it gets wet, it will expand and ruin it.
SeaBass
| posted on 29/4/07 at 08:29 PM |
Hence the need to seal it with the first coat, so other coats don't soak in. It takes a fairly constant soaking over a few hours to expand in
truth.
| posted on 29/4/07 at 10:44 PM |
Blackboard paint should work. Aerosol just soaks in because it's so thin. I left some unpainted MDF out on the yard and it was there for months
in all weather without any serious problems. It has to be really saturated to split it.
[Edited on 30/4/07 by Peteff]
SeaBass
| posted on 30/4/07 at 08:35 AM |
It has to be really saturated to delaminate it.
Yeah it probably would, as is not laminated in the first place!
| posted on 30/4/07 at 08:51 AM |
Is that better for you?
SeaBass
| posted on 30/4/07 at 02:57 PM |
Spot on...
