mangogrooveworkshop
| posted on 15/5/07 at 09:15 PM |
Check this bonnet out......
Where would we get these hinges?
StevieB
| posted on 15/5/07 at 09:17 PM |
Mini door hinges? Or some other old car
Castrol Dave
| posted on 15/5/07 at 09:27 PM |
plan to use these on the Melos, when all the bling goes on...
Hinges
if that does not work go to Europa Specialist Spares > Brightwork > Hinges
Happiness is a state of mind...
If your not happy...change your mind.
cadebytiger
| posted on 15/5/07 at 09:28 PM |
would you need a metal bonnet? I guess so
jonno
| posted on 15/5/07 at 09:30 PM |
Welcome Dave, you got it started yet
Ketchup
| posted on 15/5/07 at 09:33 PM |
essex boy thread highjacking tonight
(is it alive dave?)
Castrol Dave
Mine is currently using narrow hinges, bolted onto bodywork and bonnet.
it just opens back to the screen doesn't appear to show any stree cracks.. but i may re-inforce the new ones just in case!
Castrol Dave
posted on 15/5/07 at 09:40 PM |
Hi
engine turns over
does not fire up
battery a bit low from leaving ignition on
got the rest of the week off work to spend some Luv on it
iank
| posted on 15/5/07 at 09:46 PM |
Look like hillman imp hinges.
Few different styles here http://www.vintagecarparts.co.uk/en/list+coachfittings+and+body+parts~hinge/
Anonymous
blockhead_rich
I bulilt a Melos as my first kit car project when I was about 20 yrs old. Ages ago now. Where abouts are you in Essex Dave as I'd quite like
to see one again.
Rich
tegwin
| posted on 15/5/07 at 09:58 PM |
Looks like Morris minor hinges...
mangogrooveworkshop
| posted on 15/5/07 at 10:10 PM |
Gaz 1977
| posted on 16/5/07 at 07:49 AM |
HINGES
i would like to see the underside of the bonnet to see what sort of support they have
CAD Monkey
| posted on 16/5/07 at 09:55 AM |
they also look a bit like the boot hinges that are fitted to the Pilgrim Sumo that Mark Evans builds in A Car is Born if that helps
sgraber
| posted on 19/5/07 at 05:56 AM |
early Mazda Rx-7 rear decklid hinges.
Steve Graber
http://www.grabercars.com/
"Quickness through lightness"
