Author: Subject: dash scuttle
dyntan
posted on 16/6/07 at 07:27 PM Reply With Quote
dash scuttle
i'm at the stage of fabbing the dash scuttle. has anyone got any dimensions i can use as the book is a bit unclear. looking for things like the height and how deep to make it.
any ideas greatfully accepted
paul
mark chandler
posted on 16/6/07 at 09:44 PM Reply With Quote
Personal preference....
I laid a board across the top of my engine from the nose cone then used this to determine the hieght possible without needing a bonnet bulge.
The curves on the sides are a different matter, I followed the curves again from the nose cone as if its extended back to the larger width.
Issue with this is that purchased windscreens will not fit so you have to fab your own.
Regards Mark
[Edited on 16/6/07 by mark chandler]
