CraigJ
| posted on 19/7/07 at 03:47 PM |
Rivit sizes & sealant for attaching panals
Going to pick up the rivits in a bit, what size do you lot recomend to attach the ali to 25mm box section for the floor and sides?
Also what sealant/bonder do you recomend? or what can i use from B&Q lol. or do i need to order some?
[Edited on 19/7/07 by CraigJ]
| posted on 19/7/07 at 04:06 PM |
I used 4mm dia closed end rivets (stops the moisture getting in) and black PU sealant from Decorating Direct.
robertst
| posted on 19/7/07 at 04:17 PM |
yeah i made the mistake of buying white sikaflex... look carefully which one you buy... i think theres grey, brown, white and black...
Tom
caber
| posted on 19/7/07 at 04:58 PM |
I am using 3.2 closed end rivets from Screwfix and PU adhesive from Decorating direct.
Caber
Macbeast
| posted on 19/7/07 at 05:34 PM |
What's wrong with white sikaflex ?
Just asking cos I'm going to start on floor tomorrow
Avoneer
| posted on 19/7/07 at 06:34 PM |
It's impossible to clean off all squirty outy bits and you'd see the white!
Pat...
Macbeast
| posted on 19/7/07 at 07:36 PM |
Oh ta. Bugger !
Catpuss
| posted on 19/7/07 at 09:58 PM |
For the floor I used 4.8mm x16long wide head rivets bonded with black sikaflex. On my Indy they are at 60mm intervals and used 120 in total. 60mm
seems like a good interval as the rivets naturally seem to end up at junctions of tubes.
For the sides I've used 5mm rivnuts spaced at generally 150mm so that the pannels are bolt on /off/
Avoneer
| posted on 19/7/07 at 11:07 PM |
4.8mm large head ali rivets for floor.
3.2mm normal ali rivets on last car (was fine though).
Plain black silicone - the sealant only needs to stop vibration and water ingress if you are riveting as well so doesn't have to be expensive
polyurethane stuff.
Pat...
Angel Acevedo
| posted on 19/7/07 at 11:33 PM |
You may want to go the extra mile and mask around the tubes, use a thin 1/8" or so bead of sealant making circles around rivet holes and just
trim with small radius rod whatever may have oozed out. after that, just remove masking tape.
You may leave it as is or paint over....
