saigonij
posted on 15/8/07 at 08:49 PM |
need help with grp nosecone
hi all,
i started to try and get the resin off the nose cone today ,
so i started to rub it down with 1500 grit wet and dry...
which kinda worked,
except that the grp is now very dull and has lost its high gloss shine...
How do i get it back???????
emsfactory
| posted on 15/8/07 at 08:54 PM |
from 1500 you need to use a course grit. Something like G6. to get the base shine back. Then use G3 to get the good shine.
cerbera
| posted on 15/8/07 at 08:55 PM |
Farcla G3 then G10 and some elbow grease should do the trick.
saigonij
| posted on 15/8/07 at 08:58 PM |
FFFEEEEEWWWWWWWWW
i thought i had bungled it right up.
so you guys recon i can get the shine back then!
emsfactory
| posted on 15/8/07 at 11:07 PM |
Yep. I would use something coarser than g3 to start with. On the farclia website it recommends using g6 from 1500 grit paper
pmw
| posted on 16/8/07 at 01:20 PM |
Anyone recommend where you can buy 1500 grit, finest I can find is 1200
40inches
| posted on 16/8/07 at 03:07 PM |
I got 1500 and 2000 grit from Halfrauds
saigonij
| posted on 18/8/07 at 05:48 PM |
Cheers guys.
1500 wet and dry, followed by G6 for ages, followed by G3 for ages made it all shine again!!!!
thanks for the help guys, a real bacon saver!
