Author: Subject: Interesting grp moulding instructions
Hammerhead
posted on 30/8/07 at 10:11 PM Reply With Quote
Just thought i'd share this.
http://www.instructables.com/id/EUAJPQ0F2FRV86O/?ALLSTEPS
Steve.
mr henderson
posted on 31/8/07 at 07:03 AM Reply With Quote
Some interesting stuff there. I liked the 'lost foam' method of making ducts.
He didn't say much about how to get a smooth surface on the moulds, though. I know from experience that that is probably the hardest part of the whole process.
I wonder what the UK equivalent of the clear packing tape is? Brown tape can be quite difficult to remove. Maybe sellotape?
smart51
posted on 31/8/07 at 07:12 AM Reply With Quote
You can get celotape in the same size as brown parcel tape. Polyester resin doesn't stick to either, which is nice for making small parts without moulds.
I use an old window for making flat pieces. Lovely smooth finish and it doesn't stick.
RazMan
posted on 31/8/07 at 08:09 AM Reply With Quote
That reminds me of the method of making odd shapes with polyester fleece material. You stretch the material over a former and simply wet it with resin. The result is suprisingly strong.
Raz
posted on 31/8/07 at 10:05 AM Reply With Quote
remember I was asking what material to make ribs?
in the end I used two methods:
1. bubble wrap rolled into a tube and held in place with sikaflex type stuff. lay the CSM over the top. What can be lighter than air and some plastic? .... but I foudn that the epoxy does not stick to it so it can be pulled out.= - even lighter and neater
2. carboard covered in polyester sheet - the stuff that the resin does not stick too. once set, pull out the carboard and then the sheet.
oin both cases one end of the rib is open -clearly this could not be done if it was sealed.
