Author: Subject: cutting herringbone trim
jabbahutt
posted on 15/10/07 at 05:51 PM Reply With Quote
Evening all
Just trimmed one of the front wings with the old herringbone trim and got all the way round.
What's the best way to cut it without crimping the metal inside so I can still get the end over the wing?
I thought hacksaw but thought I'd check before making a lash of it as it looks really good and things haven't been going well on the car of late so this makes a nice change
Help with best tool for making a neat job appreciated.
thanks
Nigel
Humbug
posted on 15/10/07 at 06:19 PM Reply With Quote
I've always cut it with wire snippers (side cutters?), then opened it out with a large flat-bladed screwdriver. Then trial fit it - if a bit too loose, pinch up the edges again a bit
DavidM
posted on 15/10/07 at 09:08 PM Reply With Quote
I used a junior hacksaw.
RazMan
posted on 15/10/07 at 10:19 PM Reply With Quote
Sharp side cutters
Raz
posted on 16/10/07 at 07:52 AM Reply With Quote
The steel inside is arranged like teeth
_|--|_|--|_|--|
(sorry for the bad ASCII drawing!)
I used strong side-cutters - first cut a bit over-sized, then trim back until I'm not trying to cut through a thick bit of steel.
I suggest that you play with an end (ooer!) to see what I mean.
HTH
posted on 16/10/07 at 05:48 PM Reply With Quote
I used an old pair of tinsnips, quick and a clean cut.
