Author: Subject: GRP scuffs
bassett
posted on 23/12/07 at 12:52 AM Reply With Quote
GRP scuffs
Hi just got my new kit and scuffed some of the GRP, anything i can use on this to take it back to the nice shiny stuff? im sorry if this has been asked before but ive had trouble searching the forum.
Fozzie
posted on 23/12/07 at 01:06 AM Reply With Quote
Try this thread......
http://www.locostbuilders.co.uk/viewthread.php?tid=66888
HTH Fozzie
Mr Whippy
posted on 23/12/07 at 01:10 AM Reply With Quote
I'm assuming its gel coated then.
Fine grade 1000 wet and dry (with loads of soapy water) or 600 till any deep scratches are removed then back too the 1000, then as fine a grade as you can get.
After all that work, use paint rubbing compound (Halfords stock it in flat tins) that's courser than T-cut. By that point it will be quite shiny and original T-cut can be used to finish it off, note there are now two grades of T-cut one for regular use (rubbish stuff) and the original.
There's no quick way of doing it and don't go to deep or you'll hit the glass layer. You will also most likely hit very small bubbles, ignore them, a coat of wax will sort that out.
see that /\ some sod drops that in while I'm typing, oh why do I bother
[Edited on 23/12/07 by Mr Whippy]
UncleFista
posted on 23/12/07 at 03:00 AM Reply With Quote
Originally posted by bassett
<snip>ive had trouble searching the forum.
Try using % symbols instead of spaces
Tony Bond / UncleFista
posted on 23/12/07 at 10:14 AM Reply With Quote
I've used Autosol buffed with a little polishing pad on the dremel-substitute tool... Worked well (just don't hold it one place for too long or you'll over-heat the gelcoat and it goes dull). The best approach is to rapidly move up / down side / side over the part being polished. Did the job nicely for me!!!
Triton
posted on 23/12/07 at 10:19 AM Reply With Quote
Elbow grease and wet n dry then cutting compound but watch out you don't cook the gel coat...yellow will turn a weird colour.
Oh and wear a mask if using a polisher as cutting compound tastes disgusting as it flies everywhere....get in a reeeet mess well I do but then I seem to get lagged in resin ...
Mark
bassett
posted on 23/12/07 at 01:33 PM Reply With Quote
ok cool thats great guys so similar to what ive done on car bodywork i just wasnt sure it would be the same process because of the materials but looks like it is.
cheers
