charlierevell
| posted on 22/2/08 at 09:16 AM |
Roll Bar mount for Rain light
As a high level brake light I have just purchased a round LED rain light. (Twas only a tenner!)
I'd like to run it off the roll bar if poss rather than the rear panel.
Does anyone do a mount for the roll bar with a nice CNC clamp that i could use to mount a plate to and then mount the light to that?
Would weld a plate on for neatness but i dont have a welder and havent welded for a long time.
here's the light i have
LED Rain Light
Its on an angle so cant be jubilee clipped into place.
[Edited on 22/2/08 by charlierevell]
Tango orange is an 'IN' colour!!
Mr Whippy
| posted on 22/2/08 at 09:20 AM |
you could just carve a wooden block, paint it silver and glue it and the lamp to the bar. Very locost but would look just fine.
charlierevell
| posted on 22/2/08 at 09:31 AM |
I want it locost... but i think i'd rather use a lump of plastic in that case!
ditchlewis
| posted on 22/2/08 at 09:59 AM |
but wood would be more eco friendly
it would reduce the carbon fot print of your car
ditch
charlierevell
| posted on 22/2/08 at 10:41 AM |
Yeah thanks guys! haha
Would that be someway to getting thru the congestion charges? Eco friendly style!
Any sensible ideas about? I'd like to get it done this weekend
bigrich
| posted on 22/2/08 at 10:53 AM |
3 fitted to a welded bracket on the cage
could you use some exhaust type clamps and ally plate to make a non permanent mount
sucksqueezebangblow
| posted on 22/2/08 at 01:49 PM |
I have the same challenge. Been thinking about using the clamps that are often used to fit headlights or clip-on bars to motorcycle fork down-tubes,
but haven't compared roll bar diameter to down-tube diameter yet to see if it is feasible.
charlierevell
| posted on 22/2/08 at 03:49 PM |
I want it just like the above but not welded as i cant...
Im getting close to checking drainpipe clip dimensions and using those mounted to either some plate or relatively thick plastic.
The dilema continues....
