Author: Subject: How can I counter sink fibreglass accurately?
Steve Lovelock
posted on 9/3/08 at 01:47 PM Reply With Quote
I am thinking of fixing the dash panel I have made to the scuttle using counter sunk head screws. This would mean that I need to counter sink the fibreglass scuttle panel accurately about twenty times. Never having counter sunk fibreglass before I was just wondering if I was asking too much?
nitram38
posted on 9/3/08 at 02:11 PM Reply With Quote
You will weaken it.
If anything you should use domeheads with load spreading washers
twybrow
posted on 9/3/08 at 02:12 PM Reply With Quote
I think you would find it would chip. I am going to use dome heads instead. Have you got an offcut or non visible bit you can try it out on?
jacko
posted on 9/3/08 at 02:18 PM Reply With Quote
HI At work i use a wood counter sunk bit the type with lots of cutting blades
Jacko
posted on 9/3/08 at 04:17 PM Reply With Quote
Really not a good idea you will just end up with crack running from the holes, in fact any screwed/bolted fixing used on GRP should use large penny washers.
worX
posted on 9/3/08 at 05:07 PM Reply With Quote
As above...
AND - you won't/don't need about 20 screws to hold it in place. (I used 8 and it's more than enough) 7 would be a fine number...
posted on 10/3/08 at 02:33 PM Reply With Quote
I used 13 4 mm hex button heads.
Steve Lovelock
posted on 10/3/08 at 05:14 PM Reply With Quote
Decided on M5 dome headed screws in the end. Have already drilled the holes so I had no option there.
Thanks for the help
