Author: Subject: Rust (damn carpet)
madmandegge
posted on 13/4/08 at 06:11 PM Reply With Quote
Rust (damn carpet)
Hi all,
Carpet in passengers foot well has caused some rust underneath, whats the best step to getting rid of it?
Would I be OK to just clean up then treat all the patches of rust with rust treatment? I'm thinking of the ones that form a protective layer while working, unsure of they all do this?
Thanks, Simon
shows area of coverage (sorry about blur)
shows up close
Paul (Notts)
posted on 13/4/08 at 06:18 PM Reply With Quote
Give it all a good rub down. Then treat it with someting like Krust, then spray it black with hammerite smooth.
Then in 3 years time do it again.
Paul
edit - may be a good idea to spray some wax or something inside the chassis tubes via the seat holes . just a thought.
[Edited on 13/4/08 by Paul (Notts)]
RazMan
posted on 13/4/08 at 06:34 PM Reply With Quote
How about filling the footwell up with water and converting it into a huge electrolysis tank? Get the polarity right and you could get rid of all the rust over night
Raz
madmandegge
posted on 13/4/08 at 07:03 PM Reply With Quote
Thanks for confirming that, just wanted to make sure.
I could submerge the whole car...anyone know the affect of electrolysis on a complete engine? I don't fancy being the guinea pig for that just yet
edit - Having said that, I have checker/chequer plate on the driver's side, was going to do the same to the passenger side, but you suggesting repeating treatment in 3 years or so, would riveting floor down seem like a bad idea?
[Edited on 13/4/08 by madmandegge]
jlparsons
posted on 13/4/08 at 07:15 PM Reply With Quote
I second the Krust idea. You don't even have to give it much of a rub. I also use a decent zinc primer over that (one with enough zinc content to actually give sacrificial protection) then paint. Then you only have to do it every 6 years.
Any resemblance to real persons, living or dead is purely coincidental. Some assembly required. Batteries not included. Contents may settle during shipment. Use only as directed. No other warranty expressed or implied. Do not use while operating a motor vehicle or heavy equipment. Subject to approval, terms and conditions apply. Apply only to affected area. For recreational use only. All models over 18 years of age. No user-serviceable parts inside. Subject to change. As seen on TV. One size fits all. May contain nuts. Slippery when wet. For office use only. Edited for television. Keep cool; process promptly.
madmandegge
posted on 13/4/08 at 07:39 PM Reply With Quote
Sounds like a plan, will hop to it, then have to start cutting floor plate
Sucks being a noobie at this!
posted on 13/4/08 at 08:07 PM Reply With Quote
Had the same problem with my floor although I didn't have carpet. Put some antislip on the floor after treating the rust to stop my feet sliding about.
graememk
posted on 13/4/08 at 08:37 PM Reply With Quote
i have thick rubber mats with carpet glued to it on my floor, i give the steel floor a good spray of oil before i put the mats back, as of yet no rust.
