Author: Subject: How much alloy should I get?
dogwood
posted on 15/4/08 at 09:32 AM Reply With Quote
Hi Guys.
Sorry if this has been covered before, but done a search and canot find the answer.
I am coming back to England next week to collect the alloy sheets for the bodywork.
Parker steel do a full 2.50x1.25x1.2mm sheet for £32.15
which is a lot cheeper than I could ever get it here in France..
Question is how many sheets do I need?
I am building the Chris Gibbs vertion.
I need enough to do all the bodywork panels, inc scuttle and interior.
Second question,
Any idea where I can get seemless tube from for the bones in the south east?
NOT Ringwood Engineering...
I've emailed Parker, but they take forever to answer..
Cheers David
Bluemoon
posted on 15/4/08 at 10:02 AM Reply With Quote
I used 4 sheets for my ali clad MK (not including scuttle, this was GRP, also no internal trim panels, as wanted a chassis exposed inside).. Make sure you get half hard. I also had mine with a plastic film on both sides to stop scratches (as some panels are visible from both sides as exposed chassis).
Dam
Syd Bridge
posted on 15/4/08 at 11:16 AM Reply With Quote
Originally posted by dogwood
Hi Guys.
Second question,
Cheers David
I've used DOM Mechanical tube from MK Wheeler tubes for years. They have a depot at Eastleigh now. Also Pipe and Tube Group, in Basingstoke.
Syd.
speedyxjs
posted on 15/4/08 at 12:59 PM Reply With Quote
Im also in need of some ali. Is there not anywhere cheaper than parker?
davie h
posted on 15/4/08 at 02:39 PM Reply With Quote
is there a metal supermarket near to where your going i got all the seamless for £44 for my roadster build
Davie
James
posted on 15/4/08 at 04:15 PM Reply With Quote
I used 3 8'x4' sheets of ali for mine.
That included bonnet but not wings, scuttle or nose cone.
HTH,
James
