Metcalfe
posted on 24/4/08 at 10:00 PM |
Front calliper Handbrake issue
If i use fiesta front callipers on my Escort MK2 rear axle for a disc conversion, how would i go about modifying them to accept a handbrake?
many thanks
clairetoo
posted on 24/4/08 at 10:07 PM |
AFAIK you cant................just fit handbrake calipers .
Front calipers are just that - front calipers .
Its cuz I is blond , innit
Claire xx
Will weld for food......
worX
posted on 24/4/08 at 10:25 PM |
As above.
Unless you fit a third "spot" caliper specifically for handbrake, could even mount it inboard maybe, if you fancied a challenge?
[Edited on 24/4/08 by worX]
blakep82
posted on 24/4/08 at 10:38 PM |
rally design seel willwood spot calipers. they should be ok for mounting to the existing discs, with the addition of a new bracket to mount them with
________________________
Kaspa
posted on 25/4/08 at 05:53 AM |
if its only for a class requirement you can easily set up a hydraulic hand brake, but for registration i think you will need a mechanical one, if so
its change calipers for a rear set i'm afraid.
Kaspa
understeer= when you hit the wall front first
oversteer=when you hit the wall back first
HP= how fast you hit the wall
Torque= how far the wall moves when you hit it
posted on 25/4/08 at 07:20 AM |
They are far too big for use as rear calipers anyway --- take a look at the rear calipers and brackets fitted to the Rover 600 these might be easily
adapted to your brackets..
Bob C
posted on 25/4/08 at 11:48 AM |
Did the early alfasuds have front handbrake?
Bob
