pewe
| posted on 23/5/08 at 10:54 AM |
To flat or not to flat?
Just finishing off the nose-cone and bonnet. Have sprayed both using cellie and about to wack on a couple of coats of clear lacquer.
Not having used lacquer in the past is it best to flat (1500 wet&dry) the colour coat before lacquering or just tack-off and then put it straight
on top?
Any advice appreciated.
Cheers, Pewe
r1_pete
| posted on 23/5/08 at 01:36 PM |
I always give it a flatting before laquering, using 1500 - 2000 w&d, once you have a uniform 'flat' finish you'll get an amazing
finish from the clear coat.
pewe
| posted on 23/5/08 at 02:32 PM |
Thanks, Pete. Thought everyone had done a poets day! Cheers, Pewe
Mr Whippy
| posted on 23/5/08 at 02:35 PM |
as above, do flatten it and then take the panels outside in the sun (ok daylight) and have a very good look for any defects or patchy areas. Only
apply very light coats of lacquer and carefully build it up. Then leave it for a few weeks before cutting it back with something like t-cut, wait a
further few weeks and then apply a good car polish. Should end up like glass if done carefully.
[Edited on 23/5/08 by Mr Whippy]
| posted on 23/5/08 at 02:42 PM |
I would flatten off using 1200 or finer up to the last coat; each successive layer should need less sanding.
the last layer I would not sand and would dilute a bit more with cellulose.
Mark Allanson
| posted on 23/5/08 at 09:02 PM |
Flat the panels with grey scotchbrite, don't get water anywhere near the paint. Apply the clearcoat (assuming 1K) and denib with 1000 and polish
back with Farecla G3, don't use T Cut as it contains ammonia and will cloud the clear.
