Author: Subject: Making Bonnet
Michael
posted on 3/6/08 at 09:45 PM Reply With Quote
Making Bonnet
Im due to make my bonnet out of 1.6mm Steel.
Has anyone else done this and how did you form it to fit the car??
Dale
posted on 3/6/08 at 10:10 PM Reply With Quote
Thats mighty heavy for a bonnet. I used 1.6 for the sides of my scuttle and it was a bitch to bend ( hammers and dollies)
Dale
Dale
my 14 and11 year old boys 22
and 19 now want to drive but have to be 25 before insurance will allow. Finally on the road
austin man
posted on 3/6/08 at 10:14 PM Reply With Quote
why not ali dead easy to work with
worX
posted on 3/6/08 at 11:03 PM Reply With Quote
Is there a reason why you want to make it out of Steel?
You are MUCH better off making it out of Ali.
posted on 4/6/08 at 07:00 AM Reply With Quote
1.6 mm steel - you are joking right?
tin tops are made from something like 0.8 mm.
I.6 mm aluminium is said by some to be over the top but steel?!?!??!
RECONSIDER - this is a bad idea - hard to bend and shape, heavy to lift, and it rusts so will need paint which is excess weight.
1.0 - 1.6 mm aluminium is the best choice for this.
hughpinder
posted on 4/6/08 at 11:13 AM Reply With Quote
You will be hard pressed (pun intended) to bend the length of a bonnet in 1.6 steel without a decent hydraulic press or rolls.
Sorry
Hugh
Michael
posted on 4/6/08 at 06:45 PM Reply With Quote
Its ok.
Will look at either thinner steel or ali (after discussing it with the decission maker)
The side panels are 1mm or 1.6 im sure, but were formed at College.
:{THC}:YosamiteSam
posted on 18/6/08 at 02:19 AM Reply With Quote
bin the steel - toooooooooooooooooooo heavy - ally is far better - easier to work with and looks cool..
RK
posted on 18/6/08 at 02:54 PM Reply With Quote
What about .5 mm galvanised steel? This is easier and cheaper for me to get than ally.
